Very nice build case. Excellent heatsinks that look gorgeous. Massive aluminium construction. Perfect for Class-A Amplifiers.
I am building right now a F5TurboV2 for a friend in this case.
By buying this product you get 39 loyalty points
This elegant 100% Aluminium DIY case with power-on indicator is equipped with high quality heat sinks and ventilated covers. It is an ideal case for integrating a large and powerful high-fidelity amplifier or any other audio setup. It has a hole on the front for an Aluminium On/Off switch, a machining on the rear panel for the IEC subbase for the power supply and two Aluminium handles. Its robust and sophisticated design ensures efficient assembly and use with a professional finish around an innovative design.
Note: Some housings are machined directly in the mass. Thus, some angles and/or edges may be sharp. It is recommended to be careful when handling this type of housing.
Internal Dimensions :
External dimensions :
Case sold to be assembled.
Characteristics :
Color | Silver |
Color | Black |
Material | Aluminium |
Internal width | 240 |
Internal depth | 360 |
Internal height | 188 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Xenofon T.
