100% Aluminium DIY Box / Case for Hi-Fi Audio Amplifier 430x410x150mm
By buying this product you get 79 loyalty points
Reference : 10334
790,00 €tax incl.
658,33 € tax excl.
This stylish DIY 100% Aluminum case with exceptional dimensions with heat sinks and ventilated covers has benefited from a particular CNC machining.
It is an ideal case to integrate a large and powerful high fidelity amplifier or any other audio editing.
It is equipped with a front hole for receiving an On / Off button and machining on the rear panel for the IEC socket for the power supply.
Its robust and sophisticated design ensures an efficient assembly and use with a professional finish around an innovative design.
Dimensions Internal:
  • Working width: 330mm
  • Effective Depth: 397mm
  • Working height: 142mm
External Dimensions:
  • Width: 430mm
  • External Depth: 410mm
  • Height: 150mm
Box sold to assemble.
Features:/ Strong>
  • Solid Brushed Aluminum
  • Anodized Silver
  • Front: 12mm
  • Faces: 4mm
  • Radiators: 400x150x40mm
  • Weight: 15.8 kg
  • Supplied with screws, IEC socket, aluminum knob, 220V switch and CNC machined aluminum feet with anti-slip rubber.
