100% Aluminium DIY Box / Case round corners 320x240x90mm Black
4.0 / 5
Reference : 11342
75,00 €tax incl.
62,50 € tax excl.
This sleek DIY 100% Aluminum case with rounded corners of 15mm radius is ideal for integrating a DAC, preamplifier, amplifier or other audio mount.
Its robust design ensures an efficient assembly and use with a professional finish./ P>
Box sold to assemble.
Dimensions Internal:
  • Working width: 230 mm
  • Working depth: 307 mm
  • Working height: 80mm
Nominal dimensions
The rectangular dimension is a measurement of the largest cuboid that can fit in the housing.
In this casen the housing can fit a parallelepiped of 78.25mm high x 230.1mm wide and 287mm long.
External Dimensions:
  • Width: 240 mm
  • Depth: 320 mm
  • Height: 90 mm
Features:/ Strong>
  • Solid Brushed Aluminum
  • Front: 8mm
  • Rear face: 4mm
  • Faces: 3mm
  • Weight: 2.6 kg
  • Color: Anodized and brushed black
  • Supplied with screws, IEC socket with fuse holder (fuse not supplied), and 4 non-slip feet
MaterialMetal
Internal width240
Internal depth287
Internal height78
Great chassis
Four points for this great chassis. Received in almost mint quality (few minor scratches) but incredible quality overall. One rating star was lost for that and two minor issues. 1. the top plate is not symmetrical and therefor cant be rotated to have the ventilation on the back of the unit which is strange. And 2. the amount of screws are exactly enough to build the chassis. so don't loose one screw or you are screwed. And why silver screws in a black chassis.. huh?? ohh okay..
This review has been posted for 100% Aluminium DIY Box / Case round corners 320x240x90mm Black
