This 100% Aluminum case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 / Pi 3 Model B & Audiophonics DAC I-Sabre V2 / V3 ES9023.
It has all the inputs / outputs required for its connection, its power supply (Jack DC 5.5 / 2.5mm), an HDMI offset and an OLED display slot.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment.
Thanks to this particularly elegant and discreet case, you have a high-performance audio solution at an excellent value for money.
Warning This product is not compatible by default (welds to be made) with the I-Sabre V1 (9341 and 10296)
Characteristics :
The housing drilling allows the AUDIOPHONICS I-Sabre DAC V2 or the AUDIOPHONICS I-Sabre DAC V3 to be used. The power supply is then via a USB-A port.
Screws supplied:
