LM3886 Stereo audiophile Amplifier Board 2x68W / 4 Ohm
This LM3886TF module is ideal for dynamic and quality stereo amplifier design with typical audiophile components. Aop inputs on DIP 8 support make it possible to change the sound at will; this module is supplied with its radiator to mount. A simple transformer is all it takes to operate.
4.0 / 5
Reference : 12040
45,90 €tax incl.
38,25 € tax excl.
This amplifier module is based on the LM3886TF bipolar high-performance circuit developed by National Semiconductor. This audiophile version features high-quality revised and corrected components such as Welwyn metal resistors and film capacitors. It has LM317 controllers, oversized output filtering coils. In addition, the filter capacitors are 10000 mF under 35V Nover brand.
This LM 3886 stereo is capable of delivering 2 x 68W continuous power (up to 135W peak) at a load of 4? with a distortion rate not exceeding 0.1% over the audible range of 20Hz and 20KHz.
With its thermal and electrical stability, this amplifier module is equipped with a dual system of sophisticated overvoltage protection (own SPiKe? technology) and undervoltage protection.
The latter intervenes when the power supply falls below 12V. The integrated relays provide protection for the speakers and have a timer to prevent "Plocs" on ignition.
This product offers dynamic, musical sound and good bass performance typical of the Class A/B class.
An excellent turnkey LM3886 module that will fit into any DIY project, from a simple stereo amplifier to a quality active multipli-amplifier for a reasonable price.
This LM3886TF version does not require a Mica or plastic insulator for the heatsink supplied with the module.
The driver part is on DIP 8 support allowing you to change the two mono AOPs at will. This way you can fine-tune the sound quality of your Hifi system. The free DIP slot 8 allows the use of a stereo OP amplifier instead of the other two mono on the sides.
ATTENTION! This module comes with yellow or green capacitors of 10µf 100 V but does not call into question these characteristics.
If you want to increase the quality of this amplifier you can replace the original capacitors by these models:
Mcap Mundorf 10µf 250V MKP.
Watch out! Watch out! Do not connect 3 PDOs at the same time (see diagram below).
Specifications :
Puissance Continue : 50W / 8Ω (THD 0.1% - 20Hz->20KHz) +/- 35V
68W / 4Ω (THD 0.1% - 20Hz->20KHz) +/- 28V
Rapport Signal/Bruit : ≥ 92dB
Sensibilité d'entrée : 1V RMS
Sous 4Ω : (Transformateur entre 16V AC)
Sous 8Ω : (Transformateur 30V AC)
Dimensions  :
  • 149 x 96x34mm
  • Entraxe de fixation du CI : 140x89mm
  • Poids : 170g
Emplacement pour AOP simple mono type NE5534
Compatible : OPA134, OP604, Muse 01, AD797, LM49710
LM3886 amplificateur stéréo NE5534
Branchement compatible AOP stéreo NE5532
Compatible NE 5532, OPA2604, OP2134, Muse 02, LM4562
LM3886 amplificateur stéréo NE5532
Channel2 (Stereo)
ClassClass A / AB
2 reviews
Good bass, Harsh treble
For me -It is imposible to listen this for long period. The treble sounds harsh, that's why I use this for bass in a 3 way active system. I compared this amplifier to LJ TTA1943 Amplifier boards 100W 8 ohm Mono that sounded much better than LM3886
This review has been posted for LM3886 Stereo audiophile Amplifier Board 2x68W / 4 Ohm
Ce module ne mérite pas le qualificatif audiophile et pose des problèmes de fiabilité.
Le filtrage de l'alimentation n'est pas au niveau d'un module "audiophile".
Les condensateurs de filtrage ne sont pas de bonne qualité,ils laissent passer un niveau de bruit audible.
Après remplacement de ces condensateurs le problème est réglé mais ce n'est pas acceptable.
Sur un des modules que j'ai acheté (j'en ai acheté 2) le relais de protection de la sortie haut-parleurs était défaillant (contact aléatoire sur une des sorties),j'ai dû aussi le remplacer.
This LM3886TF module is ideal for dynamic and quality stereo amplifier design with typical audiophile components. Aop inputs on DIP 8 support make...
