Looking for a good amplifier module?
The UCD amplifiers of the ST range offer an unbeatable quality / power / price ratio!
Available in 3 versions: 180W, 400W and 700W they can be adapted to any Hi-fi or Professional use.
The UCD400ST is a Class D digital amplifier designed for a wide range of audio applications.
Its main characteristics are an absolutely flat response curve and independent of output impedance, low distortion rate as well as low sensitivity to noise and EMI.
The modulation is based on a controlled phase-change oscillator with a low feedback rate.
Features:/ Span>
Flat response curve independent of load impedance
Very low output impedance (20 milliOhm)
Very low distortion, independent of frequency.
Very low noise circuit
Operates with symmetrical power supply
On-Off function without "ploc"
Symmetrical input
Protected against surges and short circuits.
Recommended supply voltage: +/- 57V
applications:
Monitor loudspeakers for recording studio.
Audiophile amplifiers for professionals or amateurs.
Systems Public Address
Home Theater Systems
Active loudspeakers
Item | symbol | Spec | Notes |
Output Power | PR | 400W | 4Ω, THD = 1% |
distortion | THD | P o | |
P o = 1W | |||
Noise | U n | 30uV typ | |
Frequency Response | <10Hz-50kHz | + 0, -3dB | |
Output Impedance | Z o | <20mΩ | f = 1kHz |
<150mΩ | f = 20kHz | ||
Efficiency | η | > 92% | |
Supply Ripple Rejection | PSRR | 65dB | Both rails |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric B.
HUBERT N.
