AUDIO-GD R2R 11 2019 DAC Headphone Amplifier 32bit / 384kHz DSD AMANERO
4.5 / 5
Reference : 12207
349,00 €tax incl.
290,83 € tax excl.
This product has been replaced by the new version, the AUDIO-GD R2R-11 MK2 DAC Headphone amplifier.
AUDIO-GD R2R 11 (2019)
DAC / Headphone Amplifier Audio-GD R2R 11
Versatility and efficiency
The Audio-GD R2R 11 is THE Swiss army knife for audiophiles. Combining the functions of DAC, Preamplifier and Headphone Amplifier, it will fulfill most needs./ P>
Embarking many new features, this new version of the acclaimed NFB11 now offers a discrete R2R DAC, a USB Amanero Combo 384, a dual-stage power supply, selectable digital filters and an MCU controller.
2019 update
Audio GD R2R11 Version 2019 DSD
This R2R11 benefits from 2019 update. This improvement significantly lowers noise while playing DSD (difference measured up to -14dB). The DSD mode now offers performance close to OS architecture while retaining its NOS design.
The 2019 release also includes 2018 update (removal of pops when switching from a PCM format to another).
Equipped with a USB interface Amanero Combo 384 rather than USB32, it offers both performance and compatibility. It supports sampling rates up to 32bit / 384kHz and the DXD, DSD64 and DSD128 (DSD256 and DSD512 on Windows). Its design allows it to enjoy a very low jitter.
A breathtaking sound reproduction
Non-Feedback and ACSS
The R2R 11 offers optimal performance thanks to componentss chosen carefully. Thus, in addition to supporting the DSD / DXD and sampling rates up to 32bit / 384kHz, it takes advantage of the Non-Feedback (NFB) technology developed by Audio-GD on the ACSS stage. This allows the converter to offer less sound color and therefore a faithful reproduction, a very low distortion and high linearity. You gain in dynamics, details and neutrality.
Audio-GD R2R 11 Composants
R2R
DA-8 x2
The NFB-R2R 11 now features a dual discrete R2R DAC R2R Specially designed and optimized for converting digital to analog signals. This allows output sample rate support up to 32bit / 384kHz and a 100dB Signal / Noise ratio.
High-end components
All components have been carefully selected to offer a device as powerful as durable. Thus, you will find for example an ALPS 27 potentiometer or pure copper RCA plugs.
Par défaut la position fixed est désactivée par mesure de sécurité en cas d'utilisation comme préamplificateur. Il est possible de la réactiver en déplaçant le jumper à l'intérieur de l'appareil.
Video Test of the Audio-GD R2R 11 by Z Reviews
Connections: Inputs
USB Amanerox1
Coaxialx1
Opticsx1
Connections: Outputs
RCA ACSSx1
6.35mm Jackx1
S / N118dB
Output levelHeadphone: 10V RMS / Variable: 5V Max / Fixe : 2.5V RMS (High Gain) / 1V RMS (Low Gain)
Output Headphone power3500mW (25 Ohm) / 1800mW (50 Ohm) / 900mW (100 Ohm) / 300mW (300 Ohm) / 150mW (600 Ohm)
Headphone output impedance
DAC output impedance
Coaxial Input Sensitivity0.5Vp-p (75Ω)
Optical input sensitivity19dBm
Frequency response20Hz - 20kHz (-0.2dB) / 3Hz - 350kHz (Analog)
Sample rateUSB up to 384kHz / Coaxial up to 192kHz / Optical up to 96kHz
Miscellaneous
CompatibilityWindows, Mac
Consumption12W
Weight2kg
Dimensions180 x 220 x 55mm
Accessories1x AC power cable / 1x USB cable 1.3m
OutputACSS
OutputJack 6.35mm
18 reviews
DAC R2R vs DS
Preso più per curiosità che per necessità, ora è il mio rigerimento. ho trovato un R1 usato su Subito (sempre Audiophonics) e confermo che è un ottimo marchio (Audio-GD) e un ottimo sistema. Appena possibile mi compro il R11 MKII.
This review has been posted for AUDIO-GD R2R 11 2019 DAC Headphone Amplifier 32bit / 384kHz DSD AMANERO
Wonderful DAC/AMP! As DAC itself, with signal coming from cd transport it cannot be differentiated from PCM63 or PCM1701 cd players, except in the highs. Headphone amp is also wonderful. It is very warm and sound very natural. I compare it with Topping L30 and the Audio-GD one sounds more pleasant and not that sterile. Only drawback is the highs. As non-oversampling dac, they are rolled off, starting from arround 10-11 kHz. I tried to pass the signal trough DSD, and it then shows the full range of frequencies, but the processing from PCM to DSD that the PC is making does not sounds as much pleasing as the native PCM. I had friends that are 45 years old and above, and they cannot hear the rolled off higs. I can hear it, but for me it is plus for long listening sessions, because it does not bring fatigue.
Dommage, ne m'a pas convaincu
J'étais super de le recevoir. Mais j'ai pas eu de chance.
Couplé à mon DT 990 Pro 250 Ohms, j'ai eu trop de soucis, j'ai demandé un retour, Audiophonics a été au top!
En gros:
- En optique, bruits aigus dans le casque au démarrage, puis après ça partait. DAC limité à 24 bits / 96KHz en TosLink, ce qui n'était pas grave moi. Dance ce cas là, un très beau son, sur de l'écoute de musique classique je me suis régalé.
- En USB ou en SPDIF, donc en utilisant le module interne Amanero, la cata: bruits aigus au démarrage, mais en plus distorsion horrible sur le canal gauche, qui ne partait pas...
Dommage, les divers réglages en facade sont tops, mais pour un produit neuf, je préfère passer mon chemin. A noter qu'en cherchant de l'aide sur ce problème de distorsion, je suis tombé sur des posts de personnes aux US ayant eu le même soucis après quelques mois d'utilisation, contrairement à moi où c'est arrivé dès le déballage...
Tant pis, je passe à une autre marque, je ne le sent pas...
Pour retrouver le son d'une platine vintage
Souhaitant redonner un peu de jeunesse à une chaîne pas très récente(3 Diapasons/2*100W + Enceintes et lecteur CD/DVD de la même marque)
mais donnant presque toujours satisfaction, j'ai décidé de vérifier ce qu'un DAC de moyenne gamme pouvait apporter en plus.
Mon lecteur CD/DVD "grand public" avait eu un diapason d'or, j'avais déjà ajouté un dac (entrée de gamme...aucune différence avec celui intégré au lecteur).
Ayant fourni une alimentation 12 V améliorée à ce dac antérieur(8x), j'ai pu malgré tout obtenir une amélioration (...très réduite).
Mais avec le R2R-11, jamais je n'aurais pu imaginer une telle progression. Le son est très vinyl (l'agressivité 'numérique' est presque absente).
Et paradoxalement, les notes aigües semblent différentes, comme avec un léger décalage vers plus d'aigü.
Les nuances ressortent mieux, les acteurs les moins audibles d'une scène sonore sont plus présents.
Les passages forts sont restitués vigoureusement, l'ampli est plus vif, comme tenu plus fermement(Vol. Dac au 3/4).
Après une petite période de rodage(un vingtaine d'heures), le rendu me paraît excellent;
Sur une centaine de CD, seule l'écoute de deux ou trois semble inchangée.
L'amélioration est très sensible pour les instruments traditionnels, pour les voix
et les scènes sonores complexes(orchestre classique et/ou choeurs paraissent moins confus,
en écoutant Amadeus j'ai presque retrouvé l'ampleur sonore de la salle de cinéma!).
Super ampli/DAC pour casque
Ayant un casque DT 990 PRO haute impédance, il est difficile de trouver un ampli casque puissant ...
Plus de problème avec ce modèle et la musicalité est bien au rendez-vous !
Que du bonheur !
Je recommande.
