I was looking something clean, simple and Hi-Fi minimalistic.
the costumer service is awesome as well..it took 12 days to get it (I'm located in NYC).
I'm using the RuneAudio and is great as well..THANKS
Audiophonics RaspDAC HE is a network player based on a Raspberry Pi and an ES9023 TCXO DAC. It will allow you to simply enjoy your high definition dematerialized music.
DAC network player Audiophonics I-Sabre V3 ES9023 and Raspberry Pi 3
Switch to High Definition with the RaspDAC HE. Case 100% Aluminum, DAC ES9023 24bit 192Khz TCXO, and Raspberry 3.0!
Here is an affordable solution of dematerialized reading assembled and tested in our workshops.
Completely ready to use electronically, you just have to choose the software solution of your choice (Max2Play, OSMC, Picoreplayer).
Simply get a high-end digital audio player with a 24bit / 192Khz Bit-Perfect resolution.
AUDIOPHONICS integrates the new DAC I-Sabre V3 ES9023 24 / 192Khz equipped with a TCXO precision clock and a revised and corrected mass circuit, and a new low regulation noise LDO capacitors OS Con, this DAC I-Sabre V3 is the heart of the RaspDAC.
In addition, its advanced ATX-type power management with different modes of extinction offers a high level of ease of use.
It has all the inputs / outputs necessary for its connector, its power (Jack DC 5.5 / 2.1mm), as well as an HDMI port.
(Illustration with external power supply not included)
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Particularelegantly and discreetly, it offers you the possibility to have a high-performance audio solution and achieved excellent value for money.
Raspberry Pi 3 | Model B |
DAC | I-Sabre V3 ES9023 TCXO |
inputs | 1x RJ45 / 4x USA-A / 1x Micro-SD Port |
Exits | 1x RCA Stereo |
Food | Jack DC 5.5 / 2.1mm |
Dimensions | 160 x 140 x 50mm |
Weight | 0.9kg |
Housing material | 100% Aluminum |
Color | Black |
This 100% Aluminum Case haswas designed to receive the Raspberry Pi 2/3 & Audiophonics DAC I-Sabre V3 ES9023.
Supplied accessories:
To allow you to be directly operational, the player comes with an 8GB SDHC card, and also an external standard 6V 2A power supply on 5.5 / 2.1 connector.
Improve quality (background noise reduction) with optionally, our AUDIOPHONICS regulated external linear dual regulated 2x 6V 2.9A 25VA .
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Antonio Agustin M.
Matthieu L.
