AUDIOPHONICS RaspDAC LTE I-Sabre V3 - Streamer Raspberry Pi & DAC TCXO
The RaspDAC LTE is a network player, a version of the classic RaspDAC without a screen. It allows you to simply enjoy your high definition dematerialized music. This version incorporates an ES9023 DAC, a TCXO and a Raspberry Pi 3 in a 100% Aluminum case.
Reference : 10855
199,00 €tax incl.
165,83 € tax excl.
AUDIOPHONICS RASPDAC LTE
DAC network player Audiophonics I-Sabre V3 ES9023 TCXO and Raspberry Pi 3
RaspDAC LTE
Go to the high definition dematerialized with the RaspDac LTE. Housing 100% Aluminum, DAC ES9023 24bit / 192Khz TCXO, Raspberry 3!
Here is the first affordable solution of dematerialized reading assembled and tested in our workshops.
Ready-to-use network reader electronically, you just have to choose the software solution of your choice (Max2Play, OSMC, piCorePlayer ...).
A high-end audio player ...
Simply get a high-end digital audio player with a 24bit / 192kHz Bit-Perfect resolution.
Optimized for the sole purpose of offering maximum music, Audiophonics integrates the new DAC I-Sabre V3 ES9023 24 / 192Khz equipped with a TCXO precision clock as well as a revised and corrected mass circuit, a new low noise regulation LDO capacitors OS Con the DAC I-Sabre V3 is the heart of the RaspDAC LTE.
In addition, its advanced ATX-type power management with different possible shutdown modes offers a high level of ease of use.
RaspDAC LTE
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an excellent value for money.
RaspDAC LTE
Raspberry Pi 3Model BDACAudiophonics I-Sabre V3 ES9023 TCXOinputs1x RJ45 / 4x USB-AExits1x RCA stereoFoodJack DC 5.5 / 2.1mmDimensions102 x 169 x 58mmWeight0.61kgHousing material100% AluminumColorBlack
Aluminum Case for DAC Audiophonics & Raspberry Pi 3
This 100% Aluminum case designed in our workshops receives the Raspberry Pi 3 & DAC Audiophonics I-Sabre V3 ES9023 TCXO or DAC I-TDA1387 TCXO.
RaspDAC housing
Accessories lithe following:
To enable you to be directly operational, the player comes with an 8GB SDHC card. Supplied with an external standard 5V 2A power supply on 5.5 / 2.1 connector.
Improve quality (background noise reduction) with optional, our Audiophonics linear regulated filter EMI RFI 6V 3.5A 25VA .
Color
  • Black
Super !
J'ai acheté ce petit DAC et je suis bouleversé par sa qualité. Chez moi j'en ai um Meridian série G et autres marques dites High-End mais pas ce petit RASPDAC LTE est bien sûr le champion. Je dois aussi dire que j'habite en dehors de la France, au Portugal, et l'expédition vu super rapide. M. Aubert a répondu toujours à toutes mes questions avec rapidité et professionnalisme. Merci par cet excellent professionnalisme.
Vasco Vaz
 (3)
This review has been posted for AUDIOPHONICS RaspDAC LTE I-Sabre V3 - Streamer Raspberry Pi & DAC TCXO
The RaspDAC LTE is a network player, a version of the classic RaspDAC without a screen. It allows you to simply enjoy your high definition...
