AUDIOPHONICS RaspDAC I-Sabre V3 - Streamer Raspberry Pi & DAC TCXO
The Audiophonics team is proud to introduce the RaspDAC: our brand new network drive based on a Raspberry Pi and DAC I-Sabre V3 ES9023 TCXO. Moved to high definition dematerialized with RaspDAC. 100% Aluminium housing, DAC ES9023 24bit 192kHz TCXO, Raspberry Pi !
Reference : 10369
249,00 €tax incl.
207,50 € tax excl.
Audiophonics RaspDAC I-Sabre V3
Audiophonics RaspDAC I-Sabre V3 Lecteur réseau Raspberry Pi & DAC TCXO
Moved to high definition dematerialized with RaspDAC. 100% Aluminium housing, DAC ES9023 24bit 192kHz TCXO, Raspberry Pi ! Here is an affordable solution for dematerialized reading assembled and tested in our workshops. A complete and ready-to-use network reader electronically, all you have to do is choose the software solution of your choice (Volumio, piCorePlayer, RaspBMC, Openelec...).
High end audio player
Get a very simple, high-end dematerialized audio player with a resolution of up to 24bit 192kHz in bit-perfect. Optimized for the sole purpose of offering the best of your music, Audiophonics integrates the new DAC I-Sabre V3 ES9023 24bit 192kHz equipped with a TCXO precision clock as well as a revised and corrected ground circuit and a new low LDO noise regulation of OS Con capacitors, this DAC I-Sabre V3 is the heart of the RaspDAC.
In addition, its advanced ATX power management system with different possible shutdown modes offers a high level of user comfort. It has all the necessary inputs and outputs, as well as an HDMI connector and an OLED display.
Illustration with an external 5V 2A regulated linear power supply not provided.
Your Raspberry Pi in a high quality audio environment
This RaspDAC has been designed to give you the efficiency of your Raspberry Pi in a high quality audio environment. Particularly elegant and discreet, it offers you the possibility of having a powerful and complete audio solution at an excellent quality/price ratio.
Aluminium case
This 100% Aluminium housing has been specially designed to accommodate the Raspberry Pi and DAC Audiophonics I-Sabre V3 pair. In addition to giving the device a beautiful appearance, it also protects the components from shocks and dust.
Product typeStreamer
Raspberry Pi 2Model B
DACAudiophonics I-Sabre V3 ES9023 TCXO
Supported sampling rateUp to 24bit 192kHz
ScreenOLED
Case material100% Anodized Aluminium
Connectivity1x Ethernet RJ45
4x USB-A
1x HDMI
1x Stereo RCA Output
Power connectorJack DC 5.5/2.1mm
Dimensions160 x 140 x 50mm
Display dimensions65 x 16mm
Weight0.9kg
Package1x RaspDAC
1x SDHC 8Go Card
1x Power supply
The Audiophonics team is proud to introduce the RaspDAC: our brand new network drive based on a Raspberry Pi and DAC I-Sabre V3 ES9023 TCXO....
