AUDIO-GD DI-2014 Digital Interface USB32 I2S DSD 24bit / 192kHz
Audio-GD DI-2014 Digital Interface USB32 I2s DSD 24bit/192Khz
Reference : 8947
319,00 €tax incl.
265,83 € tax excl.
New edition completely redesigned of the famous interfaces of the mark.
This interface is now equipped with a Class A power supply stage comprising 5 separate groups and enables DSD and DXD compatibility via I2S
This asynchronous USB interface is for us one of the best on the market as well in terms of both decoding and sound.
Your computer will not have anything to envy other top-of-the-line digital sources thanks to the ultra-modern VT 1731 (32bit / 384khz) Audio-GD USB32 interface.
This 2014 version also has an SPDIF input that can be selected by the front button.
This interface comes with the TCXO option (high precision) allowing one of the lowest possible jitter.
Features:/ Strong>
  • TCXO included as standard
  • Compatibility DSD / DXD
Food210-240V
Output Level
0.5 Vp-p (at 75 Ohm) @ SPDIF
3.3V pp (25MA) @ I2S
Input sensitivity 0.5 Vp-p (75 Ohms, Coaxial)
19 dBm at Optical
USB1.0, USB2.0, USB3.0 (Full Speed, High Speed, Class2)
Sampling rate supported (input)
Optical mode: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 48kHz, 48kHz, 88.2kHz, 96kHz, 192kHz, 192kHz,
Sampling rate supported (Output)
fashionUSB to I2S: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz (Up to 32bit)
fashionCoaxial to I2S: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz (Up to 24bit)
fashionUSB to coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz (Up to 24bit)
Coaxial to Coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz (Up to 24bit)
Consumption8W
WeightApprox 2.5KG
DimensionsW180 X L220 X H55 (MM, Aluminum casing)
AccessoriesUSB cable x1
