ATOHM EURUS 1-0 DIY Kit 2-Way Library Speaker (Pair)
By buying this product you get 169 loyalty points
Reference : 8059
1 698,00 €tax incl.
1 415,00 € tax excl.
This kit includes only the four lloudspeakers, their crossovers and the mounting accessories (screws, terminals, ...).
The cabinet kit is sold separately.
Atohm offers the best of its technologies and expertise to lovers of demanding personal achievements.
You will also find here the DIY Cabinet Kit for ATOHM EUROS 1-0 .
You will find in the documents enclosed below the complete technical data sheet.
This very high-end kit is built around two transducers:
  • The LD180CR4 ensures a high level of sensitivity combined with perfect reproduction in its bandwidth.
    Thanks to its exclusive technologies and the intensive optimization of sources of non-linearity, this unit delivers a signal free of distortions.
  • The SD28ND04RD is equipped with a 28mm direct-radiation silk dome and a powerful neodymium motor that gives it an exceptional 98dB performance and a very linear response as well as extreme finesse.
To get the quintessence of its exceptional transducers, this 2-way loudspeaker uses gentle slope filtering that is perfectly controlled, as well as a Bass-reflex load intelligently designed to promote low-frequency radiation and reduce airflow noises at high level.
Under their compact size and apparent simplicity, the EURUS 1.0 has not finished impressing you.
Technical specifications:
  • Bookshelf speaker: 2 channels bass reflex
  • Power consumption: 120 W eff
  • Peak Power: 300W
  • Impedance: 6 ohms
  • Sensitivity: 91dB / 2.83V / 1m
  • Frequency response: 44hz / 30 Khz
  • Boomer low medium: LD180CR4
  • Tweeter: SD28ND04RD
  • Filter: TCC technology (First order electrical structure with tweeter timing)/ Li>
  • Transition Frequency: 2500 Hz
  • Dimensions: 215 x 420 x 315 mm
  • Cabinet not supplied.
  • Parts for a pair of speakers
Set of accessories:
  • Mounted and wired filters
  • terminals
  • Screws and inserts with claw M4
  • Wiring diagram and layout
https://www.audiophonics.fr/images2/8059/8059_ATOHM_EURUS_DIY_KIT_1.jpg
Materials delivered ( This kit does not include cabinetry )
https://www.audiophonics.fr/images2/8059/8059_ATOHM_EURUS_DIY_KIT_2.jpg
2 reviews
ATOHM EURUS 1-0 Kit DIY
Je suis possesseur depuis décembre d'une paire d'EURUS 1.0 kit DIY (non achetées sur Audiophonics je le précise, mais c'est bien le même kit). Je souhaitais investir pour 10 ans dans une enceinte polyvalente, tutoyant le très haut de gamme, sans y investir le prix d'une voiture. Pour 2000 euros caisse comprise (et un peu de temps et d'huile de coude pour le montage il est vrai, on a rien sans rien) le résultat est à la hauteur : équilibre, cohérence, spatialisation, tenue en puissance, micro-détails même à faible volume, faible directivité/ large zone d'écoute, évent laminaire/facile à placer. Attention : pour en tirer le meilleur, il faut un ampli se hissant à leur niveau qualitativement... Très belles écoutes pour ma part sur du tube push/pull, du transistor classe A, de la classe D (finalement retenue car plus versatile et plus écologique). NB: un fil d'entraide et de partage est actif sur le forum HCFR.
This review has been posted for ATOHM EURUS 1-0 DIY Kit 2-Way Library Speaker (Pair)
ATOHM EURUS 1-o KIT ENCEINTE
Je viens d'acquérir ce kit , cette enceinte est d'un aspect agréable ,et d'une finition irréprochable , digne de matériel haut de gamme . Pour le montage , il n'y a pas de difficulté , il faut être dans une ambiance calme et un endroit adéquat pour réfléchir et réaliser cette tâche . Après vient la mise en place sur des pieds (environ 60 cm de haut) , les premiers essais ;et d'après les informations techniques et les tests réalisés par les revues spécialisées les impressions perçues sont bien haut niveau de mes espérances, ce sont des enceintes très équilibrées du graves aux aigues , c'est très aéré, on est étonné du registre global des fréquences pour des enceintes de bibliothèque. Elles donnent l'impression de la présence de colonnes acoustiques ,il est vrai que les ingénieurs d'ATOHM ont inclu leurs recherches les plus élaborées en la matière .Il est évident que l'amplificateur et les sources, câbles doivent être de grande qualité . (matériel :Ampli Musical Fidelity 250s et enceintes Triangles Lyrr ,(remplacées par Atohm Eurus 1). Un très grand merci pour le personnel AUDIOPNONICS pour leur amabilité ,leur efficacité dans les échanges techniques et d'orientation . Matériel très bien protégé et envoyé dans les délais les plus brefs (vacances d'été).
