AUDIOPHONICS Power Distributor Schuko 6 Plugs Aluminum 1.2m Black
Here is a pre-white black aluminum Multi-Port with 6 Schuko sockets (2 p&c + ground) 10/16A - 250V allowing reverse polarity. Its internal rails are made of brass and have a very large cross-section (about 6 mm²).
4.9 / 5
Reference : 4635
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 14-03-2025.
Power Distributor
Schuko 6 Plugs Aluminum 1,2m Black
MultiPrise Schuko 6 Ports Aluminium Noir Cablée 1,2m Noir
Here is a pre-white black aluminum Multi-Port with 6 Schuko sockets (2 p&c + ground) 10/16A - 250V allowing reverse polarity. Its internal rails are made of brass and have a very large cross-section (about 6 mm²). It is pre-wrought with a 1.20m long armoured ¨LFLEX 110CY cable, consisting of 3 conductors each 1.5mm². For more aesthetics, this cable is covered with a black nylon sheath to complete the finish. The termination socket SCHUKO BALS 230V with nickel-plated brass contacts. Ideal for professional or private use, this power strip is a high quality product, manufactured in France and compliant with CE standards.
Product typePower distributor
Plugs typeSchuko
Number of plugs6
CE StandardYes
Max nominal voltage250V AC
Max nominal current10/16A
Dimensions380 x 60 x 50mm
Power cable length1.2m
Power cable diameter9mm
Weight980g
Number of sockets6
FilteringNo
23 reviews
Super rapport qualité prix
Très bonne multiprise remplace très avantageusement mon ancienne multiprise en plastique, un sont plus aéré et plus percutant. produit de très bonne qualité! merci beaucoup a David pour les conseil en plus expédition super rapide reçu en 2 jours ! bravo Audiphonic toujours au top ;)
This review has been posted for AUDIOPHONICS Power Distributor Schuko 6 Plugs Aluminum 1.2m Black
Barrette secteur de grande qualité
Barrette secteur de grande qualité qui a pu apporter un plus indéniable à mon installation audio video.
De plus le matériau utilisé rassure sur la solidité de cette barrette.
Le prix peut paraître certes un peu élevé mais cela en vaut la peine !
Fabrication de qualité
Feels and looks good
The product looks solid and well built. Since it’s arrival has been used for a new position of my amp and speakers and that involved new (longer and different brand of) speaker cables so the whole sound in the room is currently different. I can’t therefore say if my equipment sound better with this power distributor, but I like the built
https://www.audiophonics.fr/index.php?id_product=4635&controller=product
livraison rapide , multiprise solide
Here is a pre-white black aluminum Multi-Port with 6 Schuko sockets (2 p&c + ground) 10/16A - 250V allowing reverse polarity. Its internal...
