FiiO K1 Portable USB DAC & Headphone Amplifier PCM5102 24Bit / 96kHz
Reference : 10580
49,90 €tax incl.
41,58 € tax excl.
A seductive alternative to "big" sedentary models, this tiny and affordable all-in-one delivers true Hifi quality.
The K1 is a portable DAC / Amplifier that stands out for its ergonomics and design as well as its design and electronic architecture.
Equipped with a USB interface that can support PCM audio files up to 24bit / 96KHz, this interface can be used without drivers on PC and MAC. It can be easily connected, no external power is required.
It is equipped with a PCM5102 converter with a high signal-to-noise ratio and low distortion associated with an amplification stage based on Texas TPA61332A.
Characteristics :
  • DAC: PCM5102
  • Supported PCM audio files up to 24bit / 96KHz
  • Headphone Amplification: TPA61332A
  • Input: Micro USB
  • Output: 3.5 mm jack
  • Recommended headphone impedance: 16 - 100 Ohm
  • Output Power:> 75 mW (16Ω / THD + N <1%)
  • THD + N: <0.01% (1 kHz)
  • Gain: 1.2 dB
  • Output voltage max. : 3.25 Vp-p
  • Output current max. : 35.93 mA
  • Output impedance: ≤ 1 Ω
  • Frequency response: 20 Hz ~ 20 kHz
  • Signal Noise Ratio: ≥100dB
  • Power: USB
  • Color: Titanium
  • Dimensions: 50 x 20.5 x 8mm
  • Weight 11.3g
  • Comes with USB A to Micr cableo USB
-Discover the Qobuzissime won by Fiio K1 -
Logo qobuzissime
OutputJack 3.5mm
ColorSilver
