ifi Audio iOne USB DAC Bluetooth aptX DSD DXD 24bit/384kHz
By buying this product you get 23 loyalty points
Reference : 11824
239,00 €tax incl.
199,17 € tax excl.
iFi Audio presents its latest addition to the NANO family. The DAC USB Bluetooth NANO iOne aptX AAC is the high quality wireless interface incorporating a USB 3.0 input, and a SPDIF input (switchable to output).
This DAC is ideal for any smartphone or tablet capable of streaming Spotify, Deezer, Google Chromecast and any other compatible music services with audiophile quality. It will also be very effective in USB / SPDIF interface.
IFI AUDIO ione nano APTX bluetooth
Bluetooth aptX and AAC :
IFI AUDIO ione nano APTX bluetoothThe iFi Audio NANO iOne DAC is compatible with the highest quality wireless reception in the Bluetooth aptX and AAC standard. Whether you have a PC, Mac, Android here is the closest wireless transmission of CD quality on a DAC 24bit 384khz and DSD256.
Reclock galvanic isolation:
IFI AUDIO ione nano APTX bluetoothTaking advantage of the technology of the parent brand AMR and other iF iAudio products, the NANO iOne has a galvanic isolation transformer on its SPDIF input/output guaranteeing a very low jitter rate whether in DAC mode or in USB/SPDIF interface mode.
24bit 384khz Multibit DAC :
IFI AUDIO ione nano APTX bluetoothThe iOne features the latest generation of BB BurrBrown DAC, recognized as the "best of the best" in the audiophile world. It is one of the few chipsets on the market to natively convert the DSD signal to DSD 256.
Global Master Timing :
The clock management system derived from the AMR motherboard and the famous DP777 DAC blocks jitter by creating a new clock with high stability insensitive to temperature variations.
Active noise Cancellation :
IFI AUDIO ione nano APTX bluetoothThe DAC iOne features noise suppression for the power supply (on USB port) meaning a noise floor measured 100x lower than most conventional filters.
This DAC received the Qobuzissime award. Read the test bench by clicking on the logo
Specifications :
  • Power source: USB with AMR Active Noise Cancellation
  • Formats : 44.1/48/88.2/96/176.4/192kHz PCM 2.8/3.1/5.6/6.2/11.2/12.4MHz DSD 352/384kHz DXD
  • DAC system: Bit-Perfect DSD & DXD DAC Burr Brown
  • Total harmonic distortion: <0.015%.
  • SNR: >109dB
  • Output voltage: >2.05V
  • Output impedance : <50 ohm
  • Recognized natively on Linux and Mac iOS. Installation driver for Windows
Inputs & Outputs :
  • USB 3.0 input 2.0 compatible
  • Bluetooth input with aptX AAC
  • SPDIF RCA input
  • SPDIF RCA output (input is switchable to output)
  • RCA analog audio output
Dimensions& Weight :
  • Dimensions : 106x67x28mm
  • Weight : 141g
OutputCoaxial SPDIF
ColorSilver
Impeccable !
Se branche en quelques secondes, fonctionne du premier coup, et depuis l'installation délivre une qualité sonore de très haut niveau. Bravo !
This review has been posted for ifi Audio iOne USB DAC Bluetooth aptX DSD DXD 24bit/384kHz
