Radical and noticeable evolution of the first DAP of the famous firm, FiiO X3 MK2 fulfills all its promises.
This player is compatible with almost all audio formats and can reach a sampling rate of 24bit / 192kHz.
Now equipped with a Cirrus Logic CS4398 converter, it is capable of decoding DSD files.
It now offers new interfaces for you to customize your X3.
Lightweight and stylish, the X3 MK2 hides great audio performance and allows you to fully enjoy your favorite music.
Characteristics :
- Analog output / headphone output: 3.5mm jack
- Digital Output SPDIF: 3.5mm Jack
- Line Output (PO): 3.5 mm Jack
- DAC USB with DSD 64/128 support
- Impedance: 16 ~ 150Ω
- Volume control: 120 levels
- 10 Band Equalizer (+/- 6dB)
- Right-to-left channel adjustment: 5 dB
- Gain: 2.6dB, 8.6dB
- THD + N: <0.001% at 1kHz
- Frequency response: 10Hz ~ 20kHz (+/- 0.2)
- Crosstalk : > 90 dB @ 10KΩ @ 1KHz
- Signal Noise Ratio:> 114dB
- Dynamic range:> 101dB
- Line Output Level:> 1.45Vrms
- Power: USB 5V 500mA recommended for USB 5V 1.5A
- Battery capacity: 3000 mAH
- External memory:128GB max via SDcard
- Weight: 135g
- Power supply 5V DC 2A
- 2600mAh Battery
- Autonomy:> 11 hours
- Charging time: 3 h
- Supported Audio Formats: DSD, 192k / 24b APE, 192k / 24b FLAC, 192k / 24b WAV, 96k / 24b Lossless WMA, Apple Lossless 192k /
MP2, MP3, AAC, ALAC, OGG ...
Performance of the headphone output:
- Output power 1: 224mW to 16Ω
- Output power 2: 200mW to 32Ω
- Output power 3: 24mW to 300Ω
- Frequency response: 20Hz ~ 20kHz
- Signal Noise Ratio:> 113dB
- Output Impedance: <0.2Ω to 32 Ohm
- Crosstalk:> 74dB at 1kHz
- Output Voltage:> 7.2 Vp-p
- Output Current:> 75mA
Package:
- 1x micro USB to USB-A cable
- 1x 3.5mm Jack to Coaxial SPDIF Adapter
- 1x black silicone protective case
- 2x Screen Protectors
- 3x personalization stickers
[Img-10800-left-thickbox_default]
[Img-10801-left-thickbox_default]
[Img-10802-left-thickbox_default]
[Img-10803-left-thickbox_default]
[Img-10804-left-thickbox_default]
[Img-10805-left-thickbox_default]
[Img-10838-left-thickbox_default]
[Img-10837-left-thickbox_default]
[Img-10836-left-thickbox_default]
[Img-10833-left-thickbox_default]
[Img-10834-left-thickbox_default]
[Img-10835-left-thickbox_default]
