AOIDE DAC II ESS ES9018K2M I2S DAC Module Board 32bit 384khz DSD Raspberry Pi 3 / A+ B+ / Pi 2 / I2S
This 32-bit ES918K2M dedicated Raspberry P3 32-bit DAC module on GPIO support provides high quality, high fidelity sound. Its optional TCXO clock slot and infrared sensor make it a valuable solution for designing affordable streamers.
4.0 / 5
Reference : 12509
39,90 €tax incl.
33,25 € tax excl.
DAC ESS ES9018K2M Module -
for Raspberry Pi-3
 Photo avec Pi3 vendu séparement, SBC Pi3 n'est pas inclus
A GPIO modular DAC with many features
This DAC ES9018K2M module dedicated to Raspberry Pi 3 has many advantages. Featuring a 100MHz OSC clock, it has an optional 100Mhz TCXO clock slot for increased fidelity. In addition, this DAC has an infrared sensor on the PCB to facilitate its integration.
A passiv analog stage output
This DAC also features a high-performance headphone output thanks to the implementation of a TPA6133A2 TI chips (138mW) that supports low impedance headphones (25 Ohm to 120 Ohm). The sound of a DAC is highly dependent on the active components at the output of the DAC. The DAC II has only high quality passive components.
So there is only one output resistor of the DAC, a MELF film resistor of very high precision and low noise. This way, the DAC eliminates the problems associated with the active components and restores a faithful and particularly detailed sound.
ESS SABRE Hardware volume With Volumio Special Edition AOIDE
This DAC offers a control of the internal hardware volume of the ES9018K2m provided that this specific Volumio distribution is used on this link: Volumio AOIDE DAC II. Once Volumio is installed, simply select in Playback Options as shown on the picture image. The advantages of using Volumio's internal Hardware 32/64 bit ESS SABRE DAC and non-Software volume are better dynamics and less distortion at low level.
We do not guarantee that all 16 to 24 bit resolutions are read by other Pi players distributions. We strongly recommend the use of Volumio with this DAC.
We do not guarantee that all 16 to 24 bit resolutions are read by other Pi players distributions. We strongly recommend the use of Volumio with this DAC. However, this DAC works with Max to Play and piCore Player provided you use the RPI DAC driver in the list below:
Step 1: Add the drives to the system curl -L --output ./dac_install.sh https://github.com/howardqiao/aoide-dac-drivers/raw/master/dac_install.sh && sudo chmod +x ./dac_install.sh
Step 2: run the shell sudo ./dac_install.sh
Technical caracteristics
DAC ESS TECH ES9018K2M
ArchitectureHYPERSTREAM 32 BIT 384KHZ
THD+N-120dB
DNR127dB
PCMToo 384kHz
DSDToo 5.6MHz
Sampling frequency range44.1kHz ~ 384kHz
Input
Input type1x I2S GPIO DATA, BCLK, LRCK, GND
Output
1x RCA sereo output2V
1x headphone jack 3.5mm output138mW +4dB
GEnEral VARIOUS
Dimensions65 x 62 x 23mm
Weight23g
RCA DistanceRCA : 16mm
Port / Infrared sensor 38Khz (NEC)GPIO 26 pin
SBC compatibilityRaspberry Pi 3B, 2B, B +
Channel
  • 2 (Stereo)
Input
  • I2S
  • I2S
Output
  • Jack 3.5mm
  • RCA
un bon DAC
Bon DAC fonctionne parfaitement avec Volumio, une fois le fichier téléchargé et décompressé l'image fournie permet une lecture claire de vos formats numériques. Une petite recherche sur la toile propose même des versions plus récentes de la distribution Volumio.
Attention cependant, les sortie RCA semblent fragiles.
This review has been posted for AOIDE DAC II ESS ES9018K2M I2S DAC Module Board 32bit 384khz DSD Raspberry Pi 3 / A+ B+ / Pi 2 / I2S
This 32-bit ES918K2M dedicated Raspberry P3 32-bit DAC module on GPIO support provides high quality, high fidelity sound. Its optional TCXO clock...
