FX-AUDIO D802 Digital Amplifier STA326 Class D stereo 2x50W / 8 Ohm Silver
4.5 / 5
Reference : 10674
109,00 €tax incl.
90,84 € tax excl.
Including 1,00 € for green tax
The FX-AUDIO D802 is a Class D STA326 amplifier that can be controlled via remote control. The FX-AUDIO D802 is finished in silver and comes standard with a 192kHz 24bit digital analog converter combined with an AKM AK4113 S/PDIF interface and a VT1630A VIA Audio/DSP interface.
This amplifier is a "Full Digital" amplifier, i.e. the S/PDIF signal is converted into I2s by the AK4113, then directly amplified by the STA326.
It has three digital inputs (USB, Coxial S/PDIF and Toslink optical).
Its OLED screen displays in real time the source used as well as the sampling rate of the audio file being played. Its USB Audio jack is also OTG compatible. So you can plug in an Android smartphone.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, etc...) adjustable directly from the remote control.
It will prove to be the ideal companion of any digital source.
Its ergonomics and compactness are significant assets to which is added its versatility.
FX-Audio D802 review by Qobuz
" There is no doubt that switching amplification has earned its place in quality Hi-Fi and this FX-Audio D802 model certainly positions itself as a champion in its class by offering sound quality, punch and many adjustment options, all in a minimal footprint and at a very affordable price. "
Test Qobuz
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
Characteristics:
  • S/PDIF AKM AK4113 Interface
  • Audio Controller / DSP VIA VT 1630A
  • OLED Display
  • Displaying the sampling rate
  • Amplifier module STA326 : 2 x 80W at 4 Ohm, 2 x 50W at 8 Ohm
  • Nichicon 5400µF x3, WIMA x2 filter capacitors
  • High precision clock
  • Signal to noise ratio (SNR): 100dB
  • Frequency Response: 18Hz - 22kHz
  • Digital equalizer
  • Control by remote control supplied or rotary encoder
  • Inputs: S/PDIF Optical Toslink, Coaxial and USB-B)
  • HP Outputs: On screw terminals supporting 4mm banana plugs
  • 32V 5A power supply supplied (5.5/2.5 jack connector)
  • Dimensions: 190x115x39mm
  • Weight : 700 g
  • USB-A to USB-B cable, remote control and Power supply included
  • Remote control CR2032 batteries not included
  • Direct (or Tone, or HiFi) mode, allows you to override the internal DSP, and amplify the signal live without changes.
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipSTA326
Power (W)50.0
13 reviews
RQP hors norme
Bon ampli, tient des enceintes complexes (petites Proacs) Offert à mes beaux parents pour un système au rqp imbattable et très plaisant à l'écoute...
This review has been posted for FX-AUDIO D802 Digital Amplifier STA326 Class D stereo 2x50W / 8 Ohm Silver
FX audio
Après un petit rodage... Ampli jouant dans la cours des très grands.
Superbe définition que soit dans les graves et les aigus !!!
Franchement déçu
Alors voilà, j'ai commandé la bête suite aux avis internet. Branchement de 2 triangle esprit gaïac 90w 8 ohm. Fiches banane et câble optique plaqué or.
J'allume l'ampli, je lance un cd et je me prépare à devenir sourd.....
Tout commence bien, je monte un peu le volume, ça a l'air prometteur, et tout à coup la catastrophe...
Passé le volume à 60 les triangle se mettent à claquer de tout les côtés.
J'ai eu peur les les avoir grillées.
Très surpris pour un ampli 50w avec des enceintes 90w
surtout que le son n'était pas spécialement super fort, j'avais pas encore les oreilles en sang.
Après une semaine d'utilisation j'ai revu les branchements, changé le lecteur cd, mais rien y fait.
Toujours de grand claquement a partir de 60.
Dans l'ensemble asser déçu, pas trop mal sur une freebox pour regarder des films ou les chaînes de music.
L'écran est très beau mais tellement petit que sur mon canapé à 2 mères j'arrive pas à le lire et choisir les différents mode, obligé de me lever pour choisir.
Donc dans l'ensemble très déçu par mon achat malgré son prix raisonnable.
Je me suis fait avoir par les avis internet, pour moi ça reste de made in china.
Très bien fabriqué , mais .........
..... les goûts et les couleurs ................!!
Sur des Proacs D15 , avec source Pioneer N50A ( DD , fichiers en 16.44 ou 24.88.2/96 ), YBA ligne 3 Delta DT , Audiomat Prelude Ref Mk 2 et Nad 3130.
Le FX tient correctement les HPs dans les basses , pourtant à 86 db de rendement . Souffle inaudible à 3 metres .Construit avec sérieux : la solidité est là ( fixation des entrées et sorties ) Energie étonnante.Réglages superflus .Seuls les modes HiFi ou flat avec +/- aiguës-basse ( +2 sur chaque pour moi ) sont utiles . Résultats identiques en coax et optique.Télécommande très petite mais très efficace .Esthetique propre mais très " Kitch"avec les leds bleues. A volume normal et sur des petites formations , scène stéréo très large ET stable à égalité avec mon YBA ( moins profonde que l'Audiomat ! ) , et supérieure au Nad.Mise en oeuvre immediate .... chauffe très peu .
Mais ...... Les timbres me laissent perplexes , dans leurs qualités , leurs différenciations , leurs couleurs , parfois leurs froideurs et leurs acidités ( Medium , medium aiguës , duo ou trio de Jazz - cymbales , vibraphone- ou musique baroque - violoncelle - ).
Même constat dans les basses : Certes , le boomer s'agite , mais la profondeur , la rapidité ou la latence des notes ne sont pas présentes ( piano , contrebasse ).
Dans les musiques d'ensemble , à volume normal , la musique devient confuse : la situation des instruments est aleatoire. .
En un mot , même après des dizaines d'heures d'écoutes
cet ampli nous interroge toujours sur un "manque de" ... " ou un " trop de "...
Bien entendu , j'ai comparé un '' petit'' ampli numérique à un transistor et à un tube réputés , : je n'aurais pas du !! mais il faut bien des points de repères. ( même le 3130 lui est supérieur , cette fois ci en écoute à volume modéré )
A mon avis , il se trouvera une meilleure place dans un mini système ou une installation audio autour d'un PC.
Evidemment , chacun a SES oreilles . Perso , je suis assez difficile : J'écoute la musique comme on regarde un film.
Mais je n'arrive pas à comprendre les personnes qui le trouvent superieur en tous points à des systemes réputés ..... , même une fois passé le charme ponctuel qu'il communique lors du premier branchement .
Par contre , 5 étoiles pour Audiophonics qui ont à chaque fois répondu à mes questions et ont envoyé ce FX en un temps record .
Souffle désagréable
Je suis ravi de voir que désormais il y a une mise en garde par rapport au souffle très désagréable qu émet cet ampli. Je suis très surpris qu'il n'ai pas été évoqué avant, dans aucun test, sinon j aurais repensé mon achat. Le son est très bon lorsqu'il y a de la musique, mais le souffle est franchement très désagréable.
Je suis assez déçu de ne pas avoir été prévenu avant mon achat. Bravo les test qobuz........
Rien à dire sur la qualité audio hormis que ça fait bien son job.
