AUDIOPHONICS PSU-HC Linear Regulated Power Supply 12V 5A 100VA
This regulated linear power supply 12V 5A with two jack outputs : 5.5/2.1 and 5.5/2.5, is dedicated for HiFi audio devices requiring a clean and neat power supply. It will reduce background noise, a lowering of the "ripple" harmful to the jitter on digital audio devices such as DAC or high fidelity streamers. The result is an improvement of the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and a better dynamic bass.
4.9 / 5
By buying this product you get 26 loyalty points
Reference : 11811
269,00 €tax incl.
224,17 € tax excl.
Thes components of this power supply are of first quality:
  • Metal Resistors
  • 10 capacitors filtering 6000µF/35V
  • Voltage Regulator Micrel MIC2975BWT
  • EMI RFI Filter
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two Jack DC 5.5 / 2.1 & 5.5 / 2.5, this power supply with an extremely stable 100VA transformer even under heavy load, and will allow you to make the best of the connected audio components requesting from 12V up to 5A (7.5A at peak) .
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Features:
  • Case: 100% Brushed and sanded aluminum
  • Black Anodized
  • Input Voltage: AC 220V
  • Output Voltage / Current: 12V 5A DC (7.5A at peak)
  • 1 output Jack DC 5.5 / 2.1mm
  • 1 DC jack output 5.5 / 2.5mm
  • IEC base with fuse holder
  • Transformer 100VA
  • Voltage Regulator MIC2975BWT
Dimensions and weight:
  • 240x170x60mm
  • Weight: 2.4kg
  • DC Jack cable not included
  • Mains cable and mains plug not included
InputIEC C14
OutputJack DC 5.5/2.5mm
OutputJack DC 5.5/2.1mm
Output voltage (V)12.0
Output current (A)5.0
Input voltage (V)230.0
Power SupplyLinear
10 reviews
Service après-vente
Mon alimentation est arrivée avec un petit défaut cosmétique sans gravité. Après une réclamation, Audiophonics m'a immédiatement répondu en me proposant un échange ou un remboursement. On ne peut que les féliciter pour la qualité de leur service après-vente !
Concernant l'appareil, il n'a pas amélioré de façon spectaculaire le son de mon Minidsp mais celui-ci n'est peut-être pas sensible aux alimentations. Je vais l'essayer sur mon Lümin D2!
Audiophonics est réellement une société en qui l'on peut accorder toute sa confiance. Thierry
This review has been posted for AUDIOPHONICS PSU-HC Linear Regulated Power Supply 12V 5A 100VA
Pour améliorer la qualité musicale d'une Box
Freebox. Bon, ok, c'est de l'informatique qui passe dedans pour mon lecteur de réseau HifiRose 250, et ça fonctionne très bien.
- "Essaie de mettre une alim linéaire de qualité pour ta box, et tu verras (écouteras en fait) le gain qualitatif".
- "Mais bien sur (gros doutes) !"
- "Je passe avec la mienne".
- "Ok"
Expérience faite, j'ai du acheter la PSU d'Audiophonics !
Si je ne m'explique pas le pourquoi c'est mieux, je constate avec évidence la très nette amélioration de "la matière sonore". Voila.
Well built
Used to power a Melco server. Solid performance.
Fantastic PSU
I ordered the audiophonics psu for my dynavector p75mk4 phono stage to replace the linear power pack supply of 12v 1a that I had for the phono.
Dynavector says that p75mk4 want's a minimum of 0,35a current, so with 1a I thought I was ok...
Man I was wrong!
When I replaced it with the Audiophonics linear PSU 12v 5a and after 150 hours of burn-in the phono stage sound fantastic!
More clarity, more bass, more hights, more depth and height of the sound stage, more fluid sound.. amazing product!
Good quality product. Would buy again.
This is a well built power supply and does the job that was intended for. The casework is heavy and robust and it doesn't get hot in my particular setup. Only criticism is the levelling of the feet as it's a bit wobbly but this is nitpicking. Very happy with it and would order again. Due to Brexit you need to stump up a £12 admin fee demanded by the UK courier. Product is recommended.
This regulated linear power supply 12V 5A with two jack outputs : 5.5/2.1 and 5.5/2.5, is dedicated for HiFi audio devices requiring a clean and...
