AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 220V to 12V 1.25A 25VA
Reference : 11375
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 11-04-2025.
alimentation linéaire 16v régulée audiophile HIFIAudiophile regulated power supply for any Hifi device running on 12V (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
EIt includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
Thecomponents of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
nsaidsi this regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
Features:
  • Case: 100% Brushed and sanded aluminum
  • Black Anodized
  • Input Voltage: AC 220V
  • Output Voltage / Current:
    • 12V 1.25A  MAX Continuous
    • 12V 2.0A  MAX (5min)
  • Outputs: 2 outputs Jack DC 5.5 / 2.1mm
  • IEC socket
  • Shielded molded anti-vibration transformer 25VA
  • AOP-controlled HEXFET IRF-type controller
  • EMI RFI filter with chokes and film capacitors
Dimensions and weight:
  • 174 x 100 x 51 mm
  • Weight: 0.850kg
  • 1x DC 5.5/2.1mm male/male jack cable with 75cm ferrites supplied
  • Power cable not included
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)12.0
Output current (A)1.25
Input voltage (V)230.0
Power SupplyLinear
19 reviews
Parfait
Le bourdonnement des hautparleurs est passé de "Wouuuu" à un légé "chhhhhhhhh"
Réduction des pics de fréquence:
50Hz: -18 dB
105Hz: -20 dB
115Hz: -15 dB
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 220V to 12V 1.25A 25VA
Très bon produit
Ce produit est très bien conçu, performant et améliore nettement les performances de mon preamplificateur phono Musical Fidelity V90 LPS, par rapport au petit adaptateur secteur fourni d'origine. Le souffle est diminué, la scène sonore plus large, c'est un plaisir. Je recommande ce produit.
Cordialement.
Jacques
TB qualité, fait parfaitement le job
Achetée pour alimenter le préampli FX-AUDIO Tube01. Une alim classique qui respire la qualité et "assurera" sans doute durant de longues années !
Great progress for little money
The heart of my hi-fi system is a miniDSP 2x4 HD. I use it as a crossover for my DIY FAST dipole speakers and for room equalization. So I thought it might be a good idea to replace the cheap plug-in power supply of this important device with this linear power supply. Given the low price, I thought I might give it a try. After a long evening of listening and testing, I now ask myself why I didn't think of this earlier. Sound impressions are always subjective, but I can clearly say that there is a sound gain. Music from any source (vinyl, CD, HiRes USB audio) sounds more confident and powerful, the stage has become wider and deeper. By nuances, but always clearly audible. As a non-technician, I can't really answer how this can be, but apparently a stable, clean power supply makes sense also for digital devices. Incidentally, as my DVD player also runs on 12 volts, I can use the second socket on the power supply unit for this. Now all the "wall warts" have disappeared from my hi-fi setup. So I would advise anyone who owns a miniDSP or similar processor: Buy an Audiophonics linear power supply!
Many thanks also to Audiophonics for the fast delivery to Germany despite the Christmas period.
Mr.
Great product! Has all the bells and whistles that you would expect from a good LPS. High grade parts are used. Good value for the price.
Thank you!
