AUDIOPHONICS Linear Power Supply double 2x 12V 2A 25VA
Reference : 10252
129,00 €tax incl.
107,50 € tax excl.
This regulated linear power supply is intended to power your amplifiers, DAC, etc ... in your DIY or other projects.
Equipped with a 100% Aluminum case, a digital display and two 5.5 / 2.1mm Jack DC outputs, this extremely stable power supply, even under heavy load, will allow you to get the best out of the connected components.
Vconnect your power supply to AC 220V, and can enjoy 2 outputs each 12V / 2A DC, ideal for powering cleanly 2 devices at the same time.
Features:
  • Case: 100% Brushed and sandblasted aluminum (5mm front)
  • Black Anodized
  • Input Voltage: AC 220V
  • Output voltage / current: 2 outputs, each 12V / 2A DC
  • Voltage adjustable via potentiometer (rear)
  • Outputs: 2x Jack DC 5.5 / 2.1mm (More to the center)
  • (IEC) and RIFA anti-noise and RFI filter
  • Phillips capacitors 2200μF 25V x4 (8800μf filtering).
  • Transformer Nuvotem Talema 25VA shielded
  • Feedback voltage compensation via AD OP177
  • 4-segment digital display with 2-decimal precision
  • Dimensions: 145 x 135 x 60 mm
  • Weight: 1.1kg
  • Cable Jack DC / Jack DC 5.5 / 2.1 shipped (50cm)
  • AC power cord not supplied
[Img-12764-left-thickbox_default]
[Img-12765-left-thickbox_default]
