FOUNTEK NEO CD2.0 Speaker Driver Ribbon Tweeter 20W 7 Ohm 97dB 1200Hz - 40kHz Ø12cm
The Fountek Neo CD2.0 ribbon tweeter has all the advantages of this technology: flat frequency response, very high quality harmonics, faster pulse response than a conventional tweeter, low resonance at 400Hz, high efficiency of 97dB, usable bandwidth from 1000Hz to 40kHz and flat impedance on this same frequency band.
Reference : 2864
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 08-11-2024.
Fountek Neo CD-2.0
Speaker Driver Ribbon Tweeter 20W 7 Ohm 97dB 1200Hz - 40kHz Ø 12cm
Fountek Neo CD-2.0 Haut-Parleur Tweeter à Ruban 20W 7 Ohm 97dB 1200Hz - 40kHz Ø 12cm
In addition, Fountek ribbon twitters are equipped with a low induction impedance transformer allowing the ribbon to perfectly match the amplifiers on the market. This makes it an excellent choice, competing directly with the best dome tweeters on the market for a lower price.
Note: Ribbon tweeters with transformers require high-pass filtering of the direct current to avoid damage to the amplifiers.
Product typeRibbon tweeter
Diaphragm typeMulti-layer aluminium
Mass of the diaphragm36mg
Diaphragm dimensions8 x 120 x 0.015mm
Ribbon area960mm²
Ribbon dimensions120mm
Magnetic field strength06 Tesla
Impedance7 Ohm
Internal resistance0.02 Ohm
Sensitibity97dB
Resonent frequency400Hz
Frequency response1200Hz - 40kHz
PowerNormal : 20W
Max : 50W
Recommended cut-off frequency2500Hz third order (18dB)
Body materialAluminium
Tweeter weight1050g
Speaker Power (W RMS)20.0
Speaker TypeRibbon tweeter
Impedance (Ω)7
Loudspeaker diameter (mm)120.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)97.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)1200
Highest frequency (Hz)40000
The Fountek Neo CD2.0 ribbon tweeter has all the advantages of this technology: flat frequency response, very high quality harmonics, faster pulse...
