FX-AUDIO D802C Bluetooth 3.0 FDA Digital Amplifier STA326 Class D 2x50W / 8 Ohm
4.7 / 5
Reference : 10399
145,00 €tax incl.
120,83 € tax excl.
A complete Class D STA326 Bluetooth amplifier with remote control, the FX-AUDIO D802C incorporates a 24-bit 192kHz analog digital converter with an AKM AK4113 S / PDIF interface, a Wolfson WM88782S ADC and a VIA VT1630A Audio / DSP interface.
This amplifier has the characteristic of being a "Full Digital", ie the S / PDIF signal is converted into I2s by the AK4113 and then directly amplified by the STA326.
In addition, it comes equipped with a Bluetooth 3.0 receiver module (CSR57E6) and a stereo RCA auxiliary input. Its USB Audio jack is also OTG compatible. So you can plug in an Android smartphone.
It has three digital inputs (USB, S / PDIF coaxial and Toslink optics).
Its OLED display displays in real time the source used as well as the sampling rate of the audio file being played.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, etc ...) adjustable directly from the remote control.
hewill prove to be the ideal companion for any digital source.
Hisergonomics and compactness are notable advantages, plus its versatility.
Features:br>
  • S & PDIF Interface AKM AK4113
  • Audio Controller / DSP VIA VT 1630A
  • ADC Wolfson WM8782S (24bit 192kHz)
  • OLED Screen
  • Displaying sampling rate
  • Wireless reception via Bluetooth 3.0 (CSR57E6)
  • STA326 amplifier module: 2 x 80W at 4 Ohm, 2x 50W at 8 Ohm
  • Filter Capacitors Nichicon 5400μF x3, WIMA x2
  • High-precision clock
  • Signal to Noise Ratio (SNR): 100dB
  • Frequency Response: 18Hz - 22kHz
  • Digital Equalizer
  • Supplied remote control or rotary encoder
  • Inputs: S / PDIF Optical Toslink, Coaxial and USB-B), stereo analog RCA
  • Outputs HP: On screwed terminal blocks supporting the banana plugs 4mm
  • Power supply 32V 5A included (5.5 / 2.5 jack connector)
  • Dimensions: 190x115x39mm
  • Weight: 700 g
  • USB-A to USB-B cable, remote control, 5dB Bluetooth antenna and power supply
  • Remote control CR2032 batteries not included
  • Direct (or Tone, or HiFi) mode, allows you to override the internal DSP, and amplify the signal live without changes.
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipSTA326
Power (W)50.0
21 reviews
Très bon rapport qualité prix
This review has been posted for FX-AUDIO D802C Bluetooth 3.0 FDA Digital Amplifier STA326 Class D 2x50W / 8 Ohm
étonnant
bonne surprise pour ce petit ampli utilisé sur une "micro chaîne" dans un bureau , il est aussi capable de remuer avec bonheur des enceintes de bon volume . peu de coloration , bonne dynamique . l'entrée analogique rca a une sensibilité inférieure aux autres .
très bon !
Je ne sais pas si un avis supplémentaire est réellement nécessaire, mais bon.
Je précise que je ne suis pas un "audiophile", mais que je suis musicien, j'ai un studio etc...
J'ai acheté cet ampli pour remplacer un vieux Pioneer des années 80, acheté d'occasion pour faire marcher des KEF Cadenza dans mon salon.
Au final, dès l'allumage on sent que c'est tout de même bien fait, ça a l'air solide, ça pèse son poids.
Le son: j'ai eu l'impression au début que le son était ultra froid et un peu sur aigu, mais après quelques réglages et 30 minutes d'écoute je me suis surtout rendu compte de la précision impressionnante du son par rapport à mon ancien ampli "vintage".
au final, pour l'utilisation que je voulais en avoir: écoute domestique avec connection bluetooth dans ma pièce à vivre tout en pouvant intégrer l'ampli discrètement dans un meuble, c'est parfait !
Je n'ai pas utilisé les autres fonctions pour l'instant (USB, entrée numérique, entrée analogique).
recadront
avec un hp coax 30 cm 96 db 1 wat Vraiment pas a la hauteur. Avec Une 2 voix bw Biblio exellent. Pas essayé sur une grosse 3 voix
UN AMPLI TRES POLYVALENT,QUALITE D'ECOUTE EXCELLENTE
J'ai possédé plus de 150 amplis en 50 ans, dont plusieurs amplis très réputés, et quelques amplis à tubes.
J'écoute ce FX AUDIO depuis un an, plusieurs heures par jour et je suis bluffé par sa qualité d'écoute et sa polyvalence.
J'entre en optique un lecteur DVD Sony S7700, en coaxial une platine vinyle Stanton ST150, en USB un petit PC sur lequel j'ai plus de 400 GO de musique et qui me sert également pour écouter Qobuz
Sur l'entrée analogique, entre un Ampli audio vidéo Marantz sur lequel sont connectés en HDMI un lecteur de DVD et un graveur DVD eux mêmes reliés à un vidéoprojecteur.
La sortie se fait sur deux enceintes BC Acoustique Araxe
Au total, ce sont 6 appareils qui sont reliés + le bluetooth !!!!
La qualité d'écoute est excellente sur les entrées numériques et très bonne sur l'entrée analogique.
Très bonne définition, très bonne image et jamais de lassitude ou d'agressivité.
Plusieurs de mes amis mélomanes et qui possèdent d'excellents systèmes, sont bluffés par l'écoute de ce minuscule ampli et de son rapport qualité prix.
Important : il faut absolument sectionner le mode HIFI, touche Tone de la télécommande et oublier les effets Jazz, Pop etc..
C'est la première fois en 50 ans, que je garde un ampli aussi longtemps, et je ne vois pas par quoi je pourrais le remplacer.
Je viens d'en commander un pour ma fille qui voulait un système complet pour brancher un téléviseur, un lecteur de DVD , un PC et une console de jeux.
Relié à un téléviseur en optique, et avec deux petites enceintes, l'écoute sera bien meilleure qu'avec la plupart des barres de son.
