This kit allows the realization of a subwoofer resolutely "Audiophile" contains everything necessary for its implementation except carpentry.
Equipped with a Direct Servo technology and a common power, it is the indispensable complement to any system worthy of the name.
Focus on Direct-Servo technology:
- The effects of thermal compression are eliminated during normal operation.
- Enables greater efficiency that would normally require a more powerful amplifier.
- The extension of the sub-basses can be achieved by using a low-mass pilot with an unmatched transient response.
- Mechanical and thermal memory effects are reduced, which improves the transient response.
- The effective value Q of 0.3 allows a much tighter and more precise control than the conventional models.
- Maximum reduction of the bass feedback in the box.
Main Features :
- HP: Driver DS1501 SLV 15 "(38 cm) high excursion with patented Direct Servo system
- Materials: Bowl and cone Aluminum, rubber suspension
- Amplifier 370W RMS Class A Servo B / Patented Controlled
- Frequency response: 14 to 200Hz (-2dB @ 14Hz) with LFE inputs in A370PEQ3 / XLR2 / XLR3
- Frequency response: 14 to 100Hz (-2dB @ 14Hz) with LINE IN inputs sur all models Li>
- 12 or 24dB / octave overlap slope (PEQ and XLR versions)
- Filter (Low Pass): 25 - 100Hz
- Filter (high pass): 20Hz 18dB / octave
- Phase phase response
- Phase adjustment from 0 to 180 degrees - continuous variation
- (Q = 0.5), mean (Q = 0.7) and low (Q = 1.1)/ Li>
Contents of the kit:
- Amplifier module: A370PEQ3 (370W RMS)
- Speakers: DS 1505 15 "38 cm
- Special subwoofer: 135 x 85 cm Li>
- Downloadable diagrams for the realization of a closed or low reflex box
Speaker Details: Strong>
- Cone rigid-cone black aluminum anodized
- High linear excursion - 1.2 "peak to peak (15mm go only) xmax
- High mechanical excursion - 1.8 "peak-to-peak (xmech) to reduce the risk of tailgating
- Low moving mass - 24 ohm ultra-thin sensor coil for controlled operation Li>
- Woven wires - prevents rattling during high excursion
- Gold plated spring terminals for easy connection of seamless cables
DS1501
[Img-11721-left-thickbox_default]
[Img-11722-left-thickbox_default]
Amplifier A370PEQ3
[Img-11723-left-thickbox_default]
Manufacturer's Datasheet (PDF)
Closed Scheme: P>
Click to open document (PDF)
P>
Bass Reflex Diagram: P>
P>
Clito open the document (PDF)
