Linear Power Supply board 4 35mm Snap in locations
Reference : 10228
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 29-04-2025.
This Linear Power Module is ideal for powering a DIY amplifier.
It allows you to integrate the 35 mm Snap-In capacitors of your choice.
The module is equipped with 4 diodes 20A 400V (directly attached to heat sinks) decoupled by 2 capacitors Vishay 0.33μF 160V.
The outputs are doubled to easily connect two amplifiers.
Characteristics :
  • Places: 4x Snap-In (Ø 36mm, 10mm spacing)
  • Diodes: FCU20A40 (20A 400V)
  • Inputs / outputs on 6mm lugs
  • Dimensions: 129x74x27mm
  • Spacing: 120x65mm
  • Weight: 85g
  • Spacers, Screws and Terminals Supplied
InputPCB Connector
OutputPCB Connector
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyLinear
