Power supply module Dual DC LM317 T 12V 1.5A
Reference : 8424
17,90 €tax incl.
14,92 € tax excl.
Its particularly rigorous design, and the quality of its components, make it an excellent choice to power any type of module or audio components requiring low voltage and clean power.
Due to its dual design without common ground, it can be used to generate 2 positive voltages, but also a symmetrical voltage.
As many environments in which it contributes to improve the sound quality, provided with two potentiometers it is possible to adjust its tension from 1.25 to 12V.
Specifications:
  • Integrated discharge resistance
  • Adjustable output voltage with potentiometers
  • Input voltage: 4.25 to 40V AC
  • Output Voltage: Variable from 1.25 to 12.2V
  • Max output current: About 1.5A continuous by rail
Characteristics :
  • Height: 40 mm
  • Dimensions: 55 x 40 x 100 mm
  • Center distance: 45 x 90 mm
  • Weight: 100 g
https://www.audiophonics.fr/images2/8424/8424_LINEAR_PSU_LT1084_1.jpg
https://www.audiophonics.fr/images2/8424/8424_LINEAR_PSU_LT1084_2.jpg
https://www.audiophonics.fr/images2/8424/8424_LINEAR_PSU_LT1084_3.jpg
https://www.audiophonics.fr/images2/8424/8424_LINEAR_PSU_LT1084_4.jpg
[Img-22037-left-thickbox_default]
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output current (A)1.5
Input voltage (V)10.0
Input voltage (V)30.0
Input voltage (V)4.0
Input voltage (V)20.0
Input voltage (V)40.0
Power SupplyRegulated Linear Power Supply
Propre, efficace, pratique
Excellent rapport qualité prix pour ce petit module d'alimentation régulée. Permet effectivement un double 12V réglable. J'alimente 2 MINI DSP 'balanced' sans souci, avec une tension finement réglable, stable, et silencieuse. Pas d'échauffement intempestif à ce jour (boitier aéré tout de même), belle qualité de PCB. Vous utiliserez ou non les connecteurs à vis très pratique que, pour ma part, je retire.
 (4)
This review has been posted for Power supply module Dual DC LM317 T 12V 1.5A
