SCHAFFNER FN9222 IEC Power Filter Anti-parasites / EMI 230V 10A
4.0 / 5
Reference : 2875
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 14-03-2025.
The benchmark for high-performance mains filters: the FN9222 model from the Swiss manufacturer SCHAFFNER, designed to filter out disturbances when capacitors are insufficient.
Single-phase male IEC model, this filter accepts a maximum voltage of 250V at the input and operating currents of up to 10A.
High efficiency against electromagnetic disturbances (EMI) propagated by radiation or conduction.
Product conforms to IEC 950, UL, CSA, TÜV, SEMKO, NEMKO and FIMKO approved standards, and meets the requirements of category II overvoltage (IEC664).
Note: For increased safety in medical applications, SCHAFFNER offers a "B" version of its filters. These products are characterized by lower leakage current, insulation resistance and higher potential test values. These are all benefits that also benefit Audio applications, for which minimizing all forms of interference and radiation harmful to the optimal operation of the equipment is an imperative and an area for continuous improvement.
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_1.jpg
Specifications :
  • Operating voltage: 250V Max 50/60Hz
  • Operating current: 10A Max
  • Leakage Current: 373µA
  • Operating Frequencies: Up to 400Hz
  • Capacity: 0.1µF x2
  • Chokes: 0.225mH x 2
  • Operating Temperature Range: -25°C to +85°C
  • Certifications : UL, CSA, TÜV, SEMKO, NEMKO & FIMKO
  • Weight: 40g
  • Built-in dimensions: 28x20.5mm
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_3.jpg
A : 48mm
B : 22.5mm
C : 40mm
D : 38.4mm
F : 5.5mm
H : 3.3mm
J : 13.3mm
S : 90°
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_2.jpg
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Contacts Plating (Connector)N/A
Rated current (A)10.0
4 reviews
Best buy
Reasonable priced, high quality EMI filter
This review has been posted for SCHAFFNER FN9222 IEC Power Filter Anti-parasites / EMI 230V 10A
Parfait
Produit conforme aux attentes
reponse à Eric M
Bonjour Eric,
Si cela peux aider, les parasites et boucles de masses peuvent intervenir dés 50hz.
Vous pouvez même le mesurer avec une appli genre "spectroid" sous google et identifier la fréquence dans vos HP.
Si les parasites sont compris entre 50 et 400hz ce filtre laissera passer le bruit.
Inefficace
Utilisé sur un ampli audio parasité par le CPL. On note une faible baisse des parasites dans le haut parleur mais ils sont toujours là.
Bonjour,
En effet, le courant CPL est extrêmement parasité.
Ce filtre SCHAFFNER est efficace mais dans la limite de "petits" parasites secteur.
