AUNE X5s 24bit DSD High Fidelity Digital Audio Player (CPLD) Black
By buying this product you get 22 loyalty points
Reference : 10504
229,00 €tax incl.
190,83 € tax excl.
AUNE unveils the X5s, a 100% digital audio player supporting virtually all formats including the DSD.
Based on the format of the X1s, it is capable of supplying high-resolution audio to all DAC's thanks to its connectivity (AES / EBU, Optical Toslink, Coaxial RCA). It accesses the files exclusively through its embed SD card reader.
With no operating system, this transport can reproduce the original recording in all its accuracy.
It is designed to be the natural companion of the X1s and then becomes a top-of-the-range set that provides a high-level DSD128 compatible digital source.
Features:
  • Architecture ARM + CPLD + DSD1793
  • High precision clocks Crystek
  • OLED display
  • Control with IR remote control
  • Supported formats: PCM 24bit 192kHz (WAV / FLAC / APE) and DSD
  • THD + N: 138.8dB at 1kHz, 0dB
  • FS Jitter: 2.7NS (PP) at 1kHz, 0dB
  • Input : SD Card Reader (128GB)
  • Transformer-insulated digital outputs: AES / EBU, RCA coaxial, Toslink optics
  • Dimensions: 171x145x45mm
  • Remote control battery not included: CR2032 (available as accessory)
  • Color : black
[Img-14383-left-thickbox_default]
[Img-14384-left-thickbox_default]
[Img-14388-left-thickbox_default]
(Illustration with the DAC Aune X1s)
[Img-14821-left-thickbox_default]
InputSD Card
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
Lecteur tous formats SD card Hi Res
Je cherchais un lecteur simple , tous formats en HD audio.
A réception de ce Aune X5s très bien emballé dans un joli carton en mousse haute densité. Petite galère pour trouver le passage en anglais car il démarre en chinois. PDF très restreint.. boouuu.
Je copie des fichiers wav sur la SD card pour démarrer. Les 44,1 kHz 16b sont bien lu, pour les 96/24 indication « not supply » pas de lecture. j’ai lu qu’il fallait enlever les métadonnées, j’ai essayé mais rien n’y fait avec des petits softs du web. Donc n’ayant autre procédure, j’ai essayé de les recopier avec mon convertisseur AVS audio de 96/24 en 96/24 wav. Mes fichiers de Qobuz Hi Res et mes SACD sont maintenant lu. J’ai testé au passage de les convertir en FLAC a toutes fréquences 44,1/24 , 48/24 , 96/24 cela fonctionne, plutôt très bien, pas ressenti de perte audio.
Les tests vont pouvoir commencer. J’ai testé les 4 sorties Spdif optic, coax, sortie ligne et AES EBU. L’AES je l’ai testé sur mon gros système multi amplifié.
L’alim , ayant opté pour « la grosse » , le message est plus posé et timbré que celle proposé avec le lecteur X5s.
Le X5s en entrée AES sur ma Yellowtec PUC2 en drive avec Foobar ASIO, puis DCX 2496 tweaké. 3 voies amplifiées, Grand mos ( mosfet). Enceinte 4 HP MTM + G . Vraiment très peu de différance sonore, peut-être un peu plus profond (tout léger retrait de medium), mais très identique, musical dynamique enfin tout bien, bien placé dans l’image.
Pour la sortie ligne pas mal, un peu moins articulée. Sortie Spdif ; Coax et optique , l’optique est un peu plus brillante malgré une fibre de bonne facture. Mais je préfère la coax , mon système est mieux réglé dessus. La qualité sonore est présente. J’ai apprécié la douceur des aigu en 96kHz-24b.
Test bien sûr avec l’AD18 qui amplifie mon atelier, conclusion identique au gros système. Avec une sortie ligne qui m’a étonné par sa qualité.
En conclusion je ne voulais plus de mon PC là ou j’écoute de la musique, pari gagné je peux écouter de la Hi Res de qualité sans déballer le tout team. ET de plus je peux arranger mes morceaux pour les adapter a mon système d’écoute vu qu’ils sont copier sur la SD. N’hésité pas a faire des folders pour ranger les morceaux car c’est lu en trie alpa tous les artistes mélangés.
A chaque frequence a priori il sort en 24 B . 44,1/24 ...lu en retour sur ma PUC2, etc
This review has been posted for AUNE X5s 24bit DSD High Fidelity Digital Audio Player (CPLD) Black
