DLNA UPNP Airplay DIY Wireless Audio Receiver Module
Module Récepteur audio sans fil Wifi DLNA UPNP Airplay DIY
Reference : 8885
34,90 €tax incl.
29,08 € tax excl.
This OEM module will allow you to add DLNA / AIRPLAY connectivity to your Audio DIY.
You can now listen to your music in your living room on your hi-fi amplifier or in your vehicle from your Smartphone, tablet or any DLNA / Airplay / UPNP compatible source etc ...
Unlike most receivers it is not the Bluetooth technology that is used here but the Wifi allowing a signal transmission without any compression or loss as well as a much greater range.
Each device is renamed in its interface to allow you to send your music in the area of ​​your choice (Lounge, Bedroom, Kitchen etc).
Capable of being used in direct connection with a smartphone (without being connected to an existing Wifi network) it can also be connected to your existing residential network.
Connected in Wi-Fi it allows to always have an auxiliary input in the 3.5 mm jack format to connect another source.
Characteristics:
  • Auxiliary input (3.5 mm stereo jack)
  • Auxiliary Output (3.5 mm stereo jack)
  • Micro-USB: Charge (transformer not delivered)
  • Wi-Fi 802.11 g / n
  • Wi-Fi / Wi-Fi client access point
  • Ability to add multiple devices (renamed in their interface to be easily identified) without limit
  • Audio Bypass Function
  • Firmware update
  • Dimensions: 66 x 66mm
Features for sharing audio content on DLNA-enabled devices:
https://www.audiophonics.fr/images2/8779/8779_airtry_music_receiver_3.jpg
Comparative table between Wi-Fi and bluetooth:
WIFI connectionBluetooth
Network coverage The entire residential areaLimited to 1 piece
Hearing quality Without lossLoss in encoding - decoding
User Experience ConvenientEasy
Limitation of compatibility Anylimited
https://www.audiophonics.fr/images2/5807/micougnou.jpg
Airtry Testby Micougnou
https://www.audiophonics.fr/images2/8885/8885_airtry_dlna_diy_wifi_2.jpg
https://www.audiophonics.fr/images2/8885/8885_airtry_dlna_diy_wifi_1.jpg
https://www.audiophonics.fr/images2/8885/8885_airtry_dlna_diy_wifi_3.jpg
https://www.audiophonics.fr/images2/8779/control_center.jpg
Possible Usage Scenarios:
https://www.audiophonics.fr/images2/8779/manual01.jpg
Smartphone / Receiver Direct Link:
https://www.audiophonics.fr/images2/8779/manual02.jpg
Networking on your residential home network:
https://www.audiophonics.fr/images2/8779/manual03.jpg
Auxiliary input:
https://www.audiophonics.fr/images2/8779/manual04.jpg
Also available with its case:
https://www.audiophonics.fr/images2/8779/8779_airtry_music_receiver_1.jpg
