-Version V2 available for the Audiophonics BT60W USB DAC Amplifier-
The Audiophonics team offers you this elegant and compact Bluetooth 3.0 Amplifier.
It has been designed around a Black Anodized Aluminum chassis and has a volume control.
Equipped with two amplifier modules TPA3110D2bridged dual mono delivering up to 2x 30W, it will very quickly become the ideal companion of your Smartphones, Tablets, PC, etc ... It also has a small amplifier headphone with its integrated circuits XPT4809 of the manufacturer Xptek.
hehas a 3.5mm jack input. You can connect it to your speakers via the HP terminal outputs or enjoy your audio files via the 3.5mm headphone jack.
This small device is full of positives and versatility, indeed the latter can also serve as DAC USBvia its micro-USB port.
Audio Test and Testphonics BT60W by Qobuz
Features:/ Strong>
- Texas Instruments TPA3110 x2 Amplifier Modules
- Headphone amplifier with specialized circuits type XPT4809
- Bluetooth Receiver 3.0 APPOTECH
- Range: 10m
- Power: 2x 30W under 4 Ohms
- Hp Protection
- Input: Jack 3.5mm
- Outputs: speaker terminals, 3.5mm jack for headphones
- On / Off switch
- Volume control
- Power Supply: 12V DC 5A included (DC Jack 5.5 / 2.5mm)
- Chassis Anodized Aluminum Black
- Dimensions: 78x70x38mm
- Weight: 100g
- Package: 3.5mm jack to RCA stereo cable, 3.5mm jack to 3.5mm jack cable 1m, 1 user manual, and its 12V power supply / adapter
