Produit mysterieux... Mais tant efficace. Des fois il suffit juste d'essayer et voila que je confirme que ca fonctionne a merveille. Faut juste ne pas en mettre de...
SURE ELECTRONICS is a specialist in audio and HiFi electronic products, such as amplifier modules, bluetooth modules, or audio amplifiers. They also own the WONDOM brand.
This amplifier module from WONDOM is a powerful 3-channel module. Powerful, it delivers up to 2x300W and 1x 500W @ 3 Ohm (THD+N = 10%). This module is based on Class D architecture and T-AMP technology, enabling 97% efficiency while maintaining high sound reproduction quality and low levels of noise and distortion.
This Wondom AA-AB35281 multi-channel amplifier uses T-Amp technology allowing it to deliver a consistent power of 3x200W under 3Ω with a high efficiency of 94%. This energy reserve allows it to be associated with a wide range of speakers, including demanding models.
This Wondom AA-AB32256 volume control module has been specially designed to accompany the Wondom AA-AB32256 and AA-AB32255 2x30W amplifier modules. It will allow an easy and quick adjustment of the sound level of these modules.
The Wondom AA-AB41161 is a high-performance signal converter, capable of converting an analog signal into an I2S signal. The signal can then be used with a digital audio system in order to obtain a very high quality sound reproduction.
The Wondom BEB1 Bluetooth receiver module, part number AA-AB41163, is a small Bluetooth receiver module featuring a QCC5171 Bluetooth 5.3 receiver chip, an ES9018K2M DAC chip and a USB-C connector input.
This WONDOM AA-AB41164 ADC module is based on a Texas Instrument Burr-Brown PCM1822 chip, enabling it to process two analog signal channels simultaneously. It can convert both unbalanced stereo analog signals and balanced stereo analog signals into I2S signals. This ADC module supports sampling rates up to PCM 24bit 192kHz.
This digital audio processor from Wondom uses an ADAU1701 26/58bit DSP chip module. This audio preamplifier/processor features a 2-channel to 4-channel configuration via RCA connectors, as well as a GPIO port for use with an external interface. The front panel also features a number of potentiometers for adjusting different frequencies (HPF/LPF filters)...
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity.
Wondom's Brick DBKL3 amplifier module offers impressive 900W mono amplification at 2Ω, based on discrete components. It was developed to meet a wide range of requirements for a wide variety of DIY applications. The module has a wide load impedance range and is equipped with numerous protections, making it both a flexible and reliable amplifier.
The Wondom AA-BK31382 is a mono Class D amplifier module capable of delivering no less than 2000W at 2Ω and this with a high efficiency of 90% as well as a high level of detail and very good dynamics.
To facilitate the use and integration of JAB3+, JAB4 and JAB5 modules, Wondom offers a kit containing all the cables and accessories needed to fully exploit their functionalities.
This package of Wondom functional cables has been designed for use with the WONDOM AA-JA32175 JAB2+ Bluetooth Amplifier Module. It includes a Bluetooth antenna, a 3.5mm jack line-in cable, a 4-pin to 4-pin speaker cable, a Bluetooth operation indicator LED, a tinned 4-pin speaker cable, a volume control potentiometer and a Bluetooth control button.
As part of the JAB range, the JAB2 offers a wireless amplification solution with an integrated Bluetooth receiver module that can be powered directly by Lithium batteries. This mono version is capable of delivering 100W of power at 2Ω thanks to a high performance TPA3116 amplifier chip. The module efficiently dissipates the heat from the amplifier thanks...
Wondom's JAB2v2 is a 1x 60W Class D amplifier module with high-resolution Bluetooth 5.0 connectivity and DSP so you can shape the sound to your liking. Moreover, this module has a mixed line output for use in conjunction with other amplifier modules to create 2.1 or 4.0 setups.
The Wondom AA-JA32151 JAB 1 is a versatile Bluetooth 2.1 stereo amplifier module delivering 2x15W at 8Ω. This new wondom JAB series offers amplification modules for mobile use. They are optimized for Lithium battery operation. It is possible to use them in mono mode (BTL).
Wondom's JAB2+ is a stereo amplifier module featuring a Bluetooth 5.0 module and integrated DSP. The JAB2+'s amplification is based on a Texas Instrument TPA3116 chip capable of delivering 35W per channel at 4Ω. For furthermore flexibility, it is also possible to configure a single 100W output at 4Ω.
Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
This flexible DSP Audio SURE ADAU 1701 allows great possibilities for digital filtering and equalization processing in a very compact integrated format.
The WONDOM AIPO2X3 amplifier module is a small stereo amplifier module capable of delivering 2x3W @ 4 ohms thanks to a Class D PAM8408 amplifier chip with integrated volume control.
This module offers a wide range of connectors to easily connect a module and a power supply with different connectors. Real Swiss Army Knife of power supply connectors.
This Wondom BCPB6 battery manager module lets you use 6 cells (lithium-ion battery) 21700 to power your electrical devices. The module enables you to achieve a considerable level of autonomy while maintaining a fairly compact form-factor with up to 88W/h to 100W/h of energy. The board's extensive connectivity makes integration quick and easy.
The Bluetooth 4.0 aptX Wondom BRB4 receiver will allow you to stream your music via Bluetooth while enjoying excellent sound quality. Indeed, this module ensures low noise and low distortion. In addition, its aptX, A2DR and +EDR technologies provide optimal transmission quality and stability.
