HDMI 2.1 Cable 8K 60Hz 48Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D Ethernet Copper 1.5m
This 1.5m-long HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps. It is also compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies.
Reference : 17971
3,90 €tax incl.
3,25 € tax excl.
HDMI 2.1 cable
Câble HDMI 2.1 8K 60Hz 48Gbps UHD EDID HDR eARC 3D Ethernet Cuivre 1.5m
This 1.5m-long HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps. It is also compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies. The cable conductors are made of copper with a cross-section of 0.051mm² (30AWG), ensuring excellent conductivity for optimum transmission. A shielding per conductor and two layers of shielding for the whole effectively repel interference that could alter the signal. The connectors are gold-plated, protecting them from oxidation while maintaining excellent conductivity.
Product typeHDMI cable
HDMI version2.1
Length1.5m
Conductors materialCopper
Conductors section0.051mm² (30AWG)
Shielding2* Aluminum foil
Magnesium-Aluminum braid
Connnectors contacts platingGold
Max supported resolutions8K (7680*4320px) @ 60Hz
4K @ 120Hz
Bandwidth48Gbps
Supported technologiesCEC
HDR
HDR 10
3D
DHCP 2.2
eARC
DDC
EDID
Color space4:4:4 max.
Color depth12bit max.
Outer diameterØ5.2
Length (m)1.5
ShieldingYes
Section (mm²)0.05
ConnectorHDMI
This 1.5m-long HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps. It is also...
