HDMI 2.1 Optical Cable 8K 60Hz 48Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 5m
This 5m-long optical HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps, and is compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies. It uses fibre optic conductors, allowing transmission over long distances without interference.
Reference : 17974
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 24-04-2025.
HDMI 2.1 Optical cable
Câble HDMI 2.1 Optique 8K 60Hz 48Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 5m
This 5m-long optical HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps, and is compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies. It uses fibre optic conductors, allowing transmission over long distances without interference, combined with tinned copper conductors. A general shielding repels any interference that might alter the signal passing over the copper conductors. The connectors feature gold-plated, oxidation-resistant contacts with a zinc alloy body that also reduces the risk of electromagnetic interference.
Product typeOptical HDMI cable
HDMI version2.1
Length5m
Conductors materialOptical fibre
Tinned copper
Shielding
Connectors contacts platingGold
Connectors body materialZinc alloy
Max supported resolutions8K (7680*4320px) @ 60Hz
4K @ 120Hz
Bandwidth48Gbps
Supported technologiesCEC
HDR
HDR 10
3D
DHCP 2.2
eARC
DDC
EDID
Color space4:4:4 max.
Color depth12bit max.
Outer diameterØ5.2mm
Length (m)5.0
ShieldingYes
Section (mm²)N/A
ConnectorHDMI
Conductors material (Cable)Optical Fiber
This 5m-long optical HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps, and is...
