PANGEA PREMIER SE MKII HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 1.5m
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity.
3.5 / 5
Reference : 17025
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-04-2025.
Pangea Audio Premier SE MKII Câble HDMI 2.1 Cuivre Cardas Plaqué Argent 8K 60Hz / 4K 120Hz HDR 48Gbps 1m
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity. Each conductor is insulated with a PE jacket and the whole cable is triple shielded to protect the signal from possible interferences that could alter its quality. The connectors are gold plated to guarantee a great durability.
Thanks to this optimal design, the Pangea Premier SE MKII benefits from a high badnwidth of 48Gbps, supports high resolution video streams up to 8K 60Hz and 4K 120Hz as well as HDR technology.
Product typeUSB cable
Length1.5m
Connectors2* Male HDMI
Cable diameterØ9.5mm
Conductors materialSilver plated Cardas copper
Conductors section0.205mm² (24AWG)
Conductors insulationPE
ShieldingTriple
Connectors contacts platingGold
Covering sheathBraided nylon
Bandwidth48Gbps
Max supported resolutions8K 60Hz
4K 120Hz
HDR support
ColorBlack and gray
Length (m)1.5
ShieldingYes
Section (mm²)0.205
ConnectorHDMI
2 reviews
correctif avis
Malheureusement, ce câble a été défaillant, mauvaise qualité de la soudure d'un des contacteurs, c'est dommage, autrement il était bien. Peut-être défaut de fabrication....
This review has been posted for PANGEA PREMIER SE MKII HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 1.5m
Très belle définition d'image
Très satisfaisant, pour un prix pas trop excessif, belle définition d'image, garantie d'une image plus contrastée tout en étant naturelle, peu de différence objective avec les câbles d'une célèbre autre marque américaine, deux à trois fois plus chers (autour de 300 à 500 euros).
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of...
