PANGEA PREMIER SE MKII HDMI Cable 3m
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity.
Reference : 18513
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 24-04-2025.
Pangea Premier SE MKII HDMI 2.1 Silver Plated Cable Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 3m
Pangea Premier SE MKII : Main view
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity. Each conductor is insulated with a PE jacket and the whole cable is triple shielded to protect the signal from possible interferences that could alter its quality. The connectors are gold plated to guarantee a great durability.
Thanks to this optimal design, the Pangea Premier SE MKII benefits from a high badnwidth of 48Gbps, supports high resolution video streams up to 8K 60Hz and 4K 120Hz as well as HDR technology.
Product typeHDMI cable
Length3m
Connectors2* Male HDMI
Cable diameterØ9.5mm
Conductors materialSilver plated Cardas copper
Conductors section0.205mm² (24AWG)
Conductors insulationPE
ShieldingTriple
Connectors contacts platingGold
Covering sheathBraided nylon
Bandwidth48Gbps
Max supported resolutions8K 60Hz
4K 120Hz
HDR support
ColorBlack and gray
Length (m)3.0
ShieldingYes
Section (mm²)0.205
ConnectorHDMI
PANGEA PREMIER SE MKII HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 3m
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of...
