Ultra HD 8K 4320p 48Gbps eARC HDMI 2.1 Cable Silver Plated OCC Copper 1.5m
This high quality 2.1 HDMI cable supports the latest 8K video standard, data rates up to 48Gbps and refresh rates up to 120Hz (4K). It is also compatible with the HDR technology now found on many TVs on the market.
4.5 / 5
Reference : 13624
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 24-04-2025.
HDMI 2.1 8K Cable
Câble HDMI 2.1 Ultra HD 8K 4320p 48Gbps Cuivre OCC Plaqué Argent 1.5m
This high quality 2.1 HDMI cable supports the latest 8K video standard, data rates up to 48Gbps and refresh rates up to 120Hz (4K). It is also compatible with the HDR technology now found on many TVs on the market, which provides a wider dynamic range for more natural colours and a more contrasting image. This cable also supports ARC, eARC, HLG, CEC and DTS:X technology.
OCC Copper & Silver Plating
With a particularly careful design specific to high-end cables, this cable uses the best materials so that you can enjoy perfect transmission of audio and video signals. This cable contains monocrystalline conductors made of OCC Copper of very high purity. Each of the 19 strands is silver plated, ensuring optimal conductivity. In the same way, both HDMI connectors are gold plated.
In addition, the cable has a 6-layer shield to drastically limit potential interference that could disturb and degrade the signal and therefore the audio and video quality at the output.
A beautiful translucent blue sheath covers the cable, ensuring both mechanical resistance and flexibility. The body of the connectors is made of chromed metal with a mirror effect.
Product typeHDMI Cable
HDMI Version2.1
Connectors2x Male HDMI
Length1.5m
Cable conductorsOCC Copper
Conductors section24AWG
Number of strands19
Cable conductors materialSilver
Connectors platingGold
Cable shieldingYes - 6 layers
Supported bandwidthUp to 48Gbps
Sheath materialPVC
ARC CompatibilityYes
eARC CompatibilityYes
Hybrid Log Gamma (HLG) CompatibilityYes
CEC CompatibilityYes
DTS:X CompatibilityYes
Number of supported channels5.1 / 7.1
Video specfications
Supported video resolution8K UHD 7680 x 4320px 60Hz
4K 120Hz
HDR SupportYes
Color SpaceBT 2020
Supported refresh rate120Hz
Chrominance subsamplingRGB 4:4:4
Gamut12bit
Connectors housing materialChromed plastic
Cable colorBlue
Package1x HDMI 1.5m Cable
Length (m)1.5
ShieldingYes
Section (mm²)0.205
ConnectorHDMI
6 reviews
Plutôt déçu, la qualité du câble est la, c'est du gros et costaud.
Mais certaines fonxtione intelligente ne passe pas, exemple, la nintendo switch la xbox one et ma box free, ne sont pas reconnue lorsqu'elles sont connectées avec ce câble à ma télé samsung.
Pourtant un pauvre câble no name hdmi 2.0 fonctionne sur ce point.
Du coup je m'interroge sur la fonctionnalité de toute la norme 2.1.
Je ne rachèterai pas ce câble, première déception chez audiophonics.
This review has been posted for Ultra HD 8K 4320p 48Gbps eARC HDMI 2.1 Cable Silver Plated OCC Copper 1.5m
La bonne affaire !
Après plusieurs tests, je le trouve aussi bon que mon audioquest carbon à 179 €. Le rapport qualité prix est donc excellent.
Vraiment un très bon câble
Remplace très avantageusement les HDMI HighSpeed de Mon....-C...e ainsi que Cinnamon de Au......st.
Je remplace tous mes HDMI par ces câbles 2.1 en cuivre OCC plaqué argent au résultat super!!
Achat sans aucun regret!!
Très bon cable
Améliore la dynamique des couleurs le grain et le son.Mais câble rigide et fiches HDMI plastique un peu légères .
RS
exelent rapport qp.
brancher entre box upc et ma tv en en 4k.. sublime image naturel dynamique et fluide.. l image est comme apaisée. le noir et le blanc ne scintille plus sais propre. les images de scènes sombres sont bien mieux détaillées et profondes. les couleurs sont vive et naturel. que demander de plus..
This high quality 2.1 HDMI cable supports the latest 8K video standard, data rates up to 48Gbps and refresh rates up to 120Hz (4K). It is also...
