2.54mm Male Pin Header Pin Header 40 Pins 5mm Rounded Gold-Plated (Unit)
Reference : 13390
2,00 €tax incl.
1,67 € tax excl.
Pin Header for PCB
40 plated round male pins Gold / pitch 2.54mm
2.54mm gold plated connector
This male pin header with rounded contacts allows to make changes to your DIY projects (Raspberry Pi, Arduino or any other SBC / Micro-controller).
The contacts are gold plated brass and so have excellent conductivity. These connectors are therefore suitable for all applications dependent on the accuracy of the electrical signal.
Each pin with its insulato forms a separable item that can be used individually.
Current3.A / Contact Max
Insulation1000MΩ @ 100V Min
Operating temperature-40 ° C / + 105 ° C
temperature solder240 ° C / 10S MAX
MaterialsPin: Brass
Plating: Gold
Insulation: PPS
No contacts2.54mm
length contacts5mm
overall dimensions2.5 x 12 x 103.5mm
ConnecticMale
Contacts number40
