C'est très bien pensé, un minimum de vis mais il faut réfléchir avant de bien le monter.
Aluminum housing 415 x 170 x 80 Front face 4 mm Black
HIFI 2000 housing Slimline serie have superb finish and are easy to assemble. The front fixation holes are drilled 45° to ensure a smooth profile with a very elegant effect once mounted.
Both side panels are made in aluminum and are 10mm thick, which allow some heat dissipation. Top and bottom panels are built in anti-scratch painted steel.
Spécifications | |||
Dimensions | Hauteur | Width | Depth |
Internal | 80 | 415 | 170 |
External | 82 | 435 | 175 |
Parts | |
Type | Self-assembly housing |
Front face | Aluminum (Black) 4mm thick |
Back panel | Aluminum (Black) 3mm Thick |
Side panels | Extruded Aluminum (Black) 10mm Thick |
Capot | Anti-sratch painted steel (Black) 1mm |
Pre-drilled for rack installation (19 inches) | Yes |
Poids | 2.1 kg |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric T.
Amaury A.
