ALLO ISOLATOR V1.3 Galvanic Isolator I2S GPIO for Katana / Boss
The Allo Isolator effectively reduces the pollution of digital audio signals transmitted in I2S via GPIO on your Raspberry Pi 3 or Allo Sparky. This version V1.3 is specifically developed and improved for the Allo Katana and Allo Boss DACs.
1.0 / 5
Reference : 13317
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 15-04-2025.
  1. Allo Isolator V1.3
Galvanic Isolator I2S GPIO for DAC Katana / Boss
Allo Isolator V1.2 Isolateur Galvanique I2S GPIO pour DAC Katana / Boss
The Allo Isolator effectively reduces the pollution of digital audio signals transmitted in I2S via GPIO on your Raspberry Pi 3 or Allo Sparky. This galvanic isolation module therefore drastically reduces the distortion of the audio signal and improves its stability for a cleaner and more accurate reproduction.
This version V1.3 of the Isolator is a model operating in Maître which can also accompany a DAC in Master mode. This galvanic isolator will adapt perfectly to DAC Allo Katana and Allo Boss. This feature allows it to have specific improvements that allow it to offer increased performance, while maintaining all the strengths of the classic version.
Note: This version 1.3 of the Allo Isolator will only work with DACs operating in master mode such as Allo Katana and Allo Boss. If you want to use a DAC in slave mode (slave) we recommend you to discover the Allo Isolator "classic" .
Note 2: This product only corresponds to Allo Isolator V1.3. SBC and DAC are sold separately.
Ce produit n'est compatible avec le système d'exploitation Volumio qu'à partir de la version 2.566 (ou plus) de ce dernier.
Product typeGalvanic isolator I2S via GPIO
SBC CompatibilityAllo Sparky
Raspberry Pi 3
NOT COMPATIBLE WITH PI 4
DAC CompatibilityMaster DACs
Power supply5V DC via USB-C (not included)
InputI2S
OutputGPIO
Does not improve sound quality, quite the opposite! Beware!
I bought Katana dac immediately with isolator. And I was not satisfied with the sound. The sound was,"dry, sterile, colorless" I listened this combination for almost half of the year because I was convinced that it should sound better than without isolator. After I read on Darko Audio review of Katana where it is stated that Katana sounds better without isolator I tested it and it is corect. Without isolator the sound is just fuller, with more details, more mids, more colors. Just better in every way. So my advice is to stay away from isolator, it does more harm than good.
This review has been posted for ALLO ISOLATOR V1.3 Galvanic Isolator I2S GPIO for Katana / Boss
The Allo Isolator effectively reduces the pollution of digital audio signals transmitted in I2S via GPIO on your Raspberry Pi 3 or Allo Sparky....
