ALLO KALI Reclocker I2S FIFO Sparky SBC and Raspberry 44/48MHz 32bit 384kHZ
This is ALLO's KALI, a Reclocker I2S FIFO 44 / 48MHz I2S Reclocker that allows you to perfectly process digital signals and send them to your DAC. It is part of the range working with the ALLO Sparky SBC universe.
4.1 / 5
Reference : 11433
119,00 €tax incl.
99,17 € tax excl.
Allo Kali
Reclocker I2S FIFO for Sparky and Raspberry Pi 44/48MHz 32bit 384kHz
reclocker allo kali
Outstanding precision
Indeed, each SBC (Sparky or Raspberry Pi) has a clock that is used to send digital signals to your DAC. The accuracy of this clock is very important in transforming the digital signal into analogue. SBCs very regularly use "first price" clocks to limit costs that are not suitable for audio use.
Example :
The Raspberry Pi3 features a 19.2 mhz clock derived from its BCM2835 processor. It cannot be clocked correctly at the frequency of 16 bit 44.1kHZ not being an exact multiple of 19.2mHZ.
It will be necessary to use a Recloker like the Allo Kali to bring a real precision to 44.1kHZ and 352.8kHZ or from 48khz to 384kHZ.
A better clock therefore means better sound and performance. The Kali will thus play this role of improving, thanks to its very weak Jitter clock fed by LDO and an ultra silent power supply.
Thanks to the KALI your music will "open up", your stage will be extended and more "three-dimensional". You will hear sounds, words and instruments that you did not previously hear when your digital signal was not processed properly.
COMPATIBILITY:
This version uses a Upsampling multiplier coefficient of X8 = 352.8kHZ for frequencies of 44.1kHZ and 384kHZ for mutliple frequencies of 48kHZ. It is therefore dedicated to DAC:
Es9016, Es9016, Es9018, Es9028pro, Es9038pro, AK4490, AK4495, AK4497, PCM1793/91/96/98, PCM1792/94/95, PCM5100/01/02, PCM5122/41/42, Wolfson 8740,8741,8742 CS4398.
For R2R and multi-bit DACs, the ALLO KALI 22/24Mhz version must be compatible with the following versions :
PCM1702, PCM1704, PCM1704, PCM56, PCM63, AD1865, TDA1541, TDA1543, TDA1387.
As well as the DAC AUDIO GD: R2R1, R2R2, DAC19, DAC 19 Singularity, DAC19 NOS, HE-7, R2R7, HE-7NOS, Master 7 Singularity, AK4399, AK4396.
hat size
The KALI ALLO must be powered by 5V / 3A via its jack plug, it cannot be powered directly by the SBC (Sparky or Raspberry Pi). However, it will power the DAC which will be connected to it.
This ALLO KALI Reclocker is HAT type and is therefore Raspberry Pi compatible. It is also Sparky SBC compatible.
Assembling tutorial RPI + Allo Kali + Allo Piano 2.1
This Buffer reclocker is compatible with the DAC Audiophonics I-Sabre ES9023, ES9018K2M and the majority of DACs that support HIFIBERRY DAC drivers.
A technical manual is available in the "Downloads"tab.
Use with external Crystal Osscillators External Crystal MCLKYes
Multi-fréquency clockWith automatic switching and improved performance
LED IndicatorsPower, Lock, Empty, Sampling rate, MCLK
Voltage regulatorUltra low noise
Designed for 32bit 384kHz DACs-
Has a UFL connectorMasterclock Out dedicated (on the back of the card)
Technical specifications
FIFO CircuitWith FPGA
I2S InputUp to 32bit 384kHz
I2S OutputUp to 32bit 384kHz
FIFO MemorySRAM 4MB
Jack Input5.5/2.5mm
DC power supply5V 3A (with filter circuits)
Operating temperature range-25°C à +85°C
Dimensions58 x 77 x 23.8mm
Weight120g
This product does not come with black spacers.
Allo kali gpio
Allo kali gpio
allo kali configuration
Example of installation with Allo DAC Piano 2.1, Kali Reclocker and Raspberry Pi 3
(Sold separately)
allo kali
InputGPIO
InputI2S
OutputGPIO
DAC / ADC ChipNC
Max sampling rate384kHz
8 reviews
new kernel issue in Volumio to decode mp3 and 24 bits!
Do you have any advice regarding the new kernel issue that blocks allo kali + piano to decode mp3 or 24bit files (play as white noise).... the 32 bit conversion trick is no good to me after trying to invest in a coherent and reliable system... if no better solution is to be found, at least updating the presentation of this product, would be a real "game change"...
This review has been posted for ALLO KALI Reclocker I2S FIFO Sparky SBC and Raspberry 44/48MHz 32bit 384kHZ
Very good
Working with Piano 2.1 the sound is really good. I recommend it
Great product from Allo. Great service from Audiophonics
Works perfectly with Allo Piano 2.1. With Kali Piano is getting much closer to Allo Revolution. A good investment if you want to play with passive DAC RPI HAT.
I should mention how quickly Audiophonics had respond to my ordering; my Kali was shipped in less than 6 hours from order confirmation which is quite impressive!
Metallic sound!
If you like metallic sound with a lot of details this is for you.
AUDIOPHONICS DAC I-Sabre ES9038Q2M sounds 10 times warmer without this reclocker.
Great sound!
I build a system consisting of a Rasperry Pi 2 (using PiCore Player), ALLO KALI Reclocker, DAC ES9038Q2M and linear power supply. The result is amazing, the sound is great (in general better and much more detailed compared to my previous sound card, a Sound Blaster X-Fi HD SB1240).
This is ALLO's KALI, a Reclocker I2S FIFO 44 / 48MHz I2S Reclocker that allows you to perfectly process digital signals and send them to your...
