Card Reader OTG Micro SD / USB-A to USB-C / Micro-USB / USB-A
This USB 2.0 Micro SD card reader makes it quick and easy to transfer content to or from a Micro SD card. Thanks to a USB-A port, you can also connect a wide range of devices such as a keyboard, mouse, gamepad, USB wifi WLAN key or USB hard drive.
Reference : 17872
4,90 €tax incl.
4,08 € tax excl.
Micro SD / USB adapter
 Micro SD / USB-A to USB-C / Micro-USB / USB-A OTG
Lecteur de Carte OTG Micro SD / USB-C / Micro-USB / USB-A
This USB 2.0 Micro SD card reader makes it quick and easy to transfer content to or from a Micro SD card. Thanks to a USB-A port, it can also be used to connect peripherals such as keyboards, mice, joysticks, WiFi USB sticks and USB hard drives.
The OTG function can only be applied to one connector at a time (Micro SD or USB-A 2.0).
Product typeMicro SD / USB-A adapter
Connectors 1* Female USB-A port
1* Micro SD slot
1* Male USB-A 2.0, convertible to male Micro USB
1* Male USB-C
Dimensions18.3*73.5mm
Weight10g
ConnecticMale & Female
ConnectorMicro USB
ConnectorMicro SD
ConnectorUSB-A
ConnectorUSB-C
This USB 2.0 Micro SD card reader makes it quick and easy to transfer content to or from a Micro SD card. Thanks to a USB-A port, you can also...
