IAN CANADA FIFOPI Q7 Synchronous FIFO Reclocker Board I2S 32bit 768kHz DSD1024 DoP256
10%
Ian Canada's FifoPi Q7 is the new flagship of the brand's reclocker range. The module manages to provide ultra low jitter and noise through the use of many new technologies.
Reduced price!
Reference : 16855
Limited special offer
249,00 €tax incl.
-10%
224,10 €tax incl.
186,75 € tax excl.
Last items in stock !
Shipping date: 01-04-2025.
This product is now replaced by the Ian Canada FifoPi Q7 II.
Ian Canada FifoPi Q7 Reclocker FIFO Synchrone I2S / DSD / DoP
Ian Canada's FifoPi Q7 is the new flagship of the brand's reclocker range. The module manages to provide ultra low jitter and noise through the use of many new technologies. It uses multi-stage discrete 1bit reclockers, low EMI leakage discrete isolators, programmable FIFO delay, automatic adaptive depth control, continuous clock mode, high performance 32bit FIFO structure and improved power supply filtering. This makes the FifoPi Q7 the perfect module for any audiophile looking to improve the sound quality of a high-end DAC, interface or streamer.
Key features :
  • Synchronous clock mode for the best possible sound quality.
  • New generation 32bit FIFO engine with 64Mb of memory.
  • Equipped with three-stage discrete 1bit low noise reclocker to ensure the best I2S/DSD signal quality. The output I2S/DSD signals are near perfect in terms of integrity.
  • Integrated discrete/optical digital isolators to ensure best isolation performance and lowest EMI leakage.
  • Supports PCM signals up to 768kHz.
  • Native DSD support up to DSD1024.
  • Integrated DoP decoder capable of playing the Raspberry Pi's native DSD stream via GPIO up to DSD256.
  • Programmable delay from 0.1s to 1s.
  • The advanced variable depth FPGA algorithm automatically adjusts the FIFO memory based on frequencies to maintain the same delay across different formats and frequencies.
  • The new continuous clock mode allows the output clocks to remain unchanged until a new frequency is locked in.
  • Possibility to use a MonitorPi (sold separately) as a FifoPi Q7 controller.
  • Works with the StationPi Pro touch screen (sold separately).
  • Two scalable XO sockets with low phase noise clocks. Support for frequencies from 5.6448MHz to 89.304MHz for 44.1kHz and 48kHz sample rates.
  • Works with the SinePi (sold separately) to use high quality external sine clocks.
  • Two separate DC inputs to provide both the FifoPi Q7's own power supply and the optional power supply for the Raspberry Pi via GPIO.
  • The power supplies with supercapacitors or LifoPO4 3.3V battery can be powered directly and cleanly.
  • Optimized high-bandwidth decoupling networks further improve power supply performance.
  • The non-isolated GPIO connector is designed to install DAC controllers, MonitorPi or other Raspberry Pi accessories without affecting the signal quality of the isolated outputs.
  • The FIFO memory works as a clock isolator so that the I2S/DSD signals are synchronized with the MCLK of the XO oscillators.
  • It has three output groups: U.FL coaxial connectors, GPIO and GPIO AUX, all independent of each other.
  • Does not require a Linux driver. Can also be used for applications without Raspberry Pi.
  • Can work with all kinds of digital audio sources such as USB, SPDIF, StationPi, StationPi Pro, etc.
  • 16 to 32bit lossless hardware converter.
  • Bit-perfect.
Product typeSynchronous FIFO reclocker
FIFO architecture32bit
FIFO memory64Mb
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD1024
Supply voltage3.3V
Dimensions75 x 65.5mm
Mounting holes spacing58 x 49mm
4 reviews
Wonderful
I purchased this board after watching some videos where DIY streaming projects were presented. I am an enthusiast with white hair now, but I still like to experiment especially with Raspberry units, which with in pi4 model have made a significant step forward also in terms of pure performance. What can I say: the board is wonderfully engineered and equally well assembled. When listening, I noticed an increase in sound definition and a greater stage with incredible separation between the various instruments, especially percussion (which I love). In short, a top product, which does not at all disfigure with my other products costing 10 times more such as the Rose Hi-Fi RS-250 or the Auralic Aries. Money definitely well spent, especially when paired with the Pure Pi and the Tranport PI (with AES/EBU connection that I use to connect with my m2Tech Young MKIII DAC.
A Thank You to my friends at Audiophile who had all the products delivered to my residence in Italy in just 48h.
Translated with www.DeepL.com/Translator (free version)
This review has been posted for IAN CANADA FIFOPI Q7 Synchronous FIFO Reclocker Board I2S 32bit 768kHz DSD1024 DoP256
Amazing
This Q7 board is a worthwhile step-up compared to the already very capable Q3 + reclocker board. As previous described, more space, detail and musicality / timbre. Highly recommended
IAN CANADA FIFOPI Q7 upgrade
I came from the ALLO Kali to this gem so a few FIFO generations have past.
Great open 3D soundstage with depth and transparency in a very dark background.
Does need some hours before opening up and start playing as it should!
Very happy user, no problems with setting up and connecting.
Big thumbs up
 (3)
FIFO PI Q3 + Reclock PI Upgrade vers FIFO PI Q7 Excellent !!
Petit retour d'expérience sur ce nouveau Reclocker de chez Ian Canada. En effet, dans mes autres post sur le FiFO PI Q3 et de de son associé le Reclock PI dont j'ai été pendant de nombreux mois très satisfait (voir mes commentaires à ce sujet), J'ai décidé de tenter l'aventure avec ce nouveau Reclocker FIFO PI Q7. Et bien, je doit dire que je suis pas déçu !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un gap significatif avec ce qui suit :
- Une amélioration de la scène sonore (plus de profondeur)
- Une dynamique plus grande
- Une plus grande justesse des timbres sur toute la plage audible
- Des fins de notes plus silencieuses
Attention cependant si vous avez des Horloges Accusilicon faire la modification sur les horloges en pliant la pin 1 pour que celles-ci ne soient pas Branchées sur leurs sockets sinon cela ne fonctionnera pas !!
Merci à Greg de Ian Canada et à l'équipe Audiophonics très réactif à ce sujet pour avoir trouvé l'origine de ce dysfonctionnement.
Seul petit bémol du FIFO PI Q7, j'ai toujours des plocs au changement de plages audio mais cependant moins fréquentes qu'avec le FIFO PI Q3.
Cordialement.
Jean-François.
Ian Canada's FifoPi Q7 is the new flagship of the brand's reclocker range. The module manages to provide ultra low jitter and noise...
