IAN CANADA ISOLATORPI III Galvanic Insulation Module
Ian Canada's IsolatorPi V3 is a HAT module that provides galvanic isolation for I2S/DSD/DoP signals, the I2C bus, some GPIO pins and power between the Raspberry Pi and digital audio modules.
Reference : 19222
95,00 €tax incl.
79,17 € tax excl.
IAN CANADA ISOLATORPI III Galvanic Insulation Module for Raspberry Pi / Odroid
IAN CANADA ISOLATORPI III picture
Ian Canada's IsolatorPi V3 is a HAT module that provides galvanic isolation for I2S/DSD/DoP signals, the I2C bus, some GPIO pins and power between the Raspberry Pi and digital audio modules. This means that it removes EMI noise from the Raspberry Pi via the ground and the audio signal, enabling your modules to work better. This progress in terms of clarity and precision in the sound reproduction of your modules is all the more evident when you use quality power supplies and clocks for them.
An improved version of the IsolatorPi II, the IsolatorPi III uses a high-quality 5KV isolator and real physical isolation of the circuits for optimum results. The Ian Canada IsolatorPi III supports I2S 768kHz and native DSD up to DSD512.
Its smart, bidirectional architecture enables it to work with audio modules in slave or master mode. Moreover, the board incorporates a second 40-pin GPIO connector (non-isolated) to enable the integration of additional modules, such as an IR receiver or rotary encoder, while preserving the isolated circuit for the audio modules.
IsolatorPi III highlights:
  • High-performance 150MHz 5KV digital isolator supporting I2S 768KHz and DSD512.
  • Physical spacing slot on the PCB to guarantee the best possible isolation space.
  • Bidirectional architecture working with audio boards in clock slave and clock master modes.
  • Native DSD output possible using companion DoP decoder via integrated connector.
  • Isolated I2C bus for audio card configuration and control.
  • Additional non-isolated 40-pin GPIO connector for connecting a MonitorPi/Pro, ESS DAC controller, IR receiver, rotary encoder and many other modules to the RPi.
  • Supports 502DAC Pro, Hifiberry Digi Pro +, and all other WM8804-based applications in master clock mode.
Dimensions et architecture du IAN CANADA ISOLATOR III
Product typeDigital galvanic isolation module 150MHz 5KV
CompatibilityRaspberryPi / ODROID
Supported sample ratesPCM : up to 768kHz
DSD native up to DSD512
ArchitectureBidirectional (operates in slave or master mode)
Power supplyIsolated circuit: 3.3V-5V DC on screw terminal block
Non-isolated circuit: via Raspberry Pi / Odroid
Inputs1x GPIO 40 pins female isolated
1x GPIO 40 pins non-isolated male
Ouput1x GPIO 40 pins isolated male
Dimensions65.5 x 65mm
Mounting holes58 x 49mm
Package1x IAN CANADA IsolatorPi III
Ian Canada's IsolatorPi V3 is a HAT module that provides galvanic isolation for I2S/DSD/DoP signals, the I2C bus, some GPIO pins and power...
