SUPTRONICS Metal Case with Button for Raspberry Pi and ST6000 / ST6000K / ST800 DAC
Reference : 12282
20,90 €tax incl.
17,42 € tax excl.
SUPTRONICS Metal case with button for Raspberry Pi and DAC ST6000 / ST6000K / ST800
Boîtier métal pour Raspberry Pi et DAC ST6000 / ST6000K / ST800
This box has been designed to accommodate both a Raspberry Pi 3, a DAC ST6000 or ST6000K, and a ST800. Thus, it has the necessary holes to easily access the connectors. Its robust metal design will allow you to protect your system from possible shocks and dust, while giving it a sober and effective design.
In addition, the housingalso comes with a push button, its jumpers and its screws, which you can fix in front of the case. A true ergonomic gain for your DIY system.
USB ST800 controller required to power the unit.
  • Compatible with Raspberry Pi 3 and DAC ST6000 / ST6000k / ST800
  • Pre-drilled housing
  • Material: Metal
  • Black color
  • Package: 1x housing, 1x push button (with screws and jumper cables)
  • Dimensions: 122 x 90 x 90mm
Color
  • Black
Material
  • Metal
un bon boitier
manque juste les accessoires (support) pour installer correctement le rpi3,
système D oblige j'ai du faire du maison mais cela fonctionne!
pour le prix il faut vraiment le coup
This review has been posted for SUPTRONICS Metal Case with Button for Raspberry Pi and ST6000 / ST6000K / ST800 DAC
