This adapter from HifiMan will allow you to connect your headphones or headphones TRRS / 3.5mm balanced Jack to a TRS / Stereo Jack 3.5mm output.
TRRS to TRS Adapter Black 15cm
This adapter from HifiMan will allow you to connect your headphones or headphones TRRS / 3.5mm balanced Jack to a TRS / Stereo Jack 3.5mm output. Thus, no more compatibility problems between your headset and your audio player. This adapter is for example included with the IEM HifiMan RE-600.
Example of 3.5mm Jack connector structure. Not representative of the proposed model.
Connector type | Female Jack 3.5mm TRRS Male Jack 3.5mm TRS |
Cable length | 15cm |
Sheath | Braided |
Color | Black |
