cet ampli NUTUBE a un rendu sonore superbe ! complémentaire aux amp 12 (plus technique) et amp13(son plus analogique avec une légère mise en avant des basses). beaucoup moins de parasites avec le wifi activé que l'amp13
Korg Nutube Amplifier Module for DX320 / DX300 DAP Blue
This iBasso AMP14 amplifier module is specifically designed to accompany the brand's DX320 and DX300 DAPs. Each module is hand tested and calibrated at the factory to provide the best possible performance. As a result, the AMP14 delivers optimal sonic performance, allowing you to enjoy a smooth and detailed music experience.
The amplification stage of the AMP14 is equipped with a 6th generation Nutube module, developed by Korg and Noritake. This module works like a classic triode tube and allows to take advantage of the roundness of this type of amplification. The Nutube adds to this an energy saving, a reduced form factor and improved performance compared to a conventional tube.
The AMP14 circuitry is meticulously designed and optimized to provide the best possible sonic performance, not to mention the typical Korg Nutube sound.
The AMP14 uses two DC-DC converters from Linear Technology for its power supply stage, for a total of 4 DC-DC power supplies. The first two supply 3.6V and 14V to the Nutube module, while the last two supply +8V and -8V to the AOP.
The AMP14 has the particularity to have two balanced outputs, one being a headphone output and the other a line output. It is therefore versatile and can be used with headphones as well as to provide an audio signal to another device.
Product type | Amplifier module for iBasso DX320 / DX300 |
Amplifier | 6th generation Korg Nutube |
Color | Blue |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
gilles A.
