IBASSO AMP8 MK2S Discrete Amplifier Module for DX240 Black
The iBasso AMP8 MK2S is an improved version of its direct predecessor, the AMP8 MK2. This one embeds better quality capacitors in order to provide perfectly optimized performances. The AMP8 MK2S is a discrete amplifier module that can be installed on the iBasso DX240 digital audio player (sold separately). Its architecture uses discrete components rather than OPAs to provide high output voltage and current, while maintaining low output impedance and offering excellent measurements.
By buying this product you get 20 loyalty points
Reference : 17367
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 22-04-2025.
iBasso AMP8 MK2S
iBasso AMP8 MK2S Module Amplificateur Discret pour DX240
The AMP8 MK2S has a voltage variation of ±8V, improving the dynamics and the headroom for a particularly precise and musical reproduction. Bipolar transistors are used and matched to ensure excellent linearity. The transistors used in the buffer stage have an output current of 2000mA, allowing the amplifier to accompany both sensitive headphones and high impedance headphones.
Finally, the AMP8 MK2S offers a double output. Indeed, there is a balanced output on a 4.4mm jack and a single-ended output on a Jack 3.5mm, allowing it to be adapted to all listening devices.
Product typeAmplification board
Output1x Balanced Jack 4.4mm
1x Single-ended Jack 3.5mm
Average autonomy9.5h
Balanced Jack 4.4mm output measurements
Max output level6.2Vrms
Output power980mW @ 32Ω
128mW @ 300Ω
Frequency response10Hz - 45kHz (±0.3dB)
SNR125dB
Dynamic range125dB
THD+N-114dB @ no load
-113dB @ 300Ω
-101dB @ 32Ω
Crosstalk-122dB
Output impedance0.55Ω
Single-ended Jack 3.5mm output measurements
Max output level3.1Vrms
Output power281mW @ 32Ω
32mW @ 300Ω
SNR122dB
Dynamic range122dB
THD+N-110dB @ bo load
-109dB @ 300Ω
-98dB @ 32Ω
Crosstalk-117dB
Output impedance0.32Ω
2 reviews
upgrade nécessaire
Je ne comptais pas sur un gap important sur un DX240 déjà remarquable...
J'utilise ce DAP avec des intras en symétrique et casque semi ouvert SR2 de la marque. Avec les deux mon DAP chauffait pas mal après deux heures d'utilisation, avec cet ampli ce n'est plus le cas. Au niveau de la qualité d'écoute du mieux un peu partout, graves profonds mediums magnifiques et aigus bien présents, la scène est très large, bref un indispensable !
This review has been posted for IBASSO AMP8 MK2S Discrete Amplifier Module for DX240 Black
Excelent
The shipping to Portugal was super fast, and item well package!
Thanks Audiophonics for that!
Has the amp, just makes the Ibasso Dx240 jump to another level of details and power.
Its a must have for the DX240.
The iBasso AMP8 MK2S is an improved version of its direct predecessor, the AMP8 MK2. This one embeds better quality capacitors in order to provide...
