XDUOO 05BL PRO Bluetooth 5.0 Receiver aptX HD LDAC for XD-05 / XD-05 PLUS
Reference : 14189
59,90 €tax incl.
49,92 € tax excl.
xDuoo 05BL Pro
xDuoo 05BL Pro Récepteur Bluetooth 5.0 aptX HD LDAC pour XD-05 / XD-05 Plus
The xDuoo 05BL Pro is an extension for the xDuoo XD-05 and XD-05 Plus, allowing these DACs/helmet amplifiers to offer Bluetooth connectivity. For this purpose, the 05BL Pro includes a Bluetooth 5.0 CSR chip supporting the aptX, aptX LL, aptX HD and LDAC codecs. These allow fast and stable wireless transmission of high-resolution files. The aptX HD technology supports file playback up to 24bit 48kHz and LDAC up to 24bit 96kHz.
This increased performance allows the BL05 Pro to play without delay and without interruption between tracks. The pieces follow each other in a fluid sequence for a total immersion. With a range of 10 meters, this Bluetooth adapter offers sufficient coverage to allow great freedom of movement.
xDuoo 05BL Pro Récepteur Bluetooth 5.0 aptX HD LDAC pour XD-05 / XD-05 PlusxDuoo 05BL Pro Récepteur Bluetooth 5.0 aptX HD LDAC pour XD-05 / XD-05 Plus
For a comfortable listening experience that is not disturbed by surrounding elements, the 05BL Pro takes advantage of the Qualcomm chip's integrated cVc noise cancellation technology. It also comes with a protection to lock the volume button on the XD-05 / XD-05 Plus to avoid the inconvenience of accidentally changing the volume level, which can affect hearing.
Operating on battery, the 05BL Pro has a very good autonomy of up to 15 hours and supports fast charging, allowing a charge in only 2 hours. It also has its own USB-C charging port, allowing it to be recharged even when it is in place.
How the 05BL Pro works
Align the 3.5mm headphone jack connectors of the BL05 Pro with those of your xDuoo XD-05 / XD-05 Plus and make the connection.
On your XD-05 / XD-05 Plus, press the source selection button to select the Coaxial input.
Keep the Power button of the 05BL Pro pressed to pair with your playback device. All you have to do is start playback.
Product typeBluetooth receiver
CompatibilityxDuoo XD-05
xDuoo XD-05 Plus
Bluetooth chipCSR8675
Bluetooth version5.0
Supported Bluetooth codecsSBC
AAC
aptX
aptX LL
aptX HD
LDAC
Max. transmission distance10m
THD+N0.00087%
Output level0.5Vp-p
Autonomy15h
Charging timeApprox. 2h
Dimensions75 x 22.8 x 14.8mm
Weight31g
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rateNC
2 reviews
Super
Articolo spedito in tempi brevissimi . confezione di alto livello, l'ho collegato al mio XDuoo Xd-05 primo modello. Nessun problema. L'impressione d'ascolto si è rivelata ottima. Non fà assolutamente rimpiangere la connessione via cavo, anzi trovo che non vi sia differenza se non a mio parere in meglio. Praticissimo senza vincoli di spostamento.
This review has been posted for XDUOO 05BL PRO Bluetooth 5.0 Receiver aptX HD LDAC for XD-05 / XD-05 PLUS
Upgrade du 05BL précédent
Ayant testé les deux extensions Bluetooth sur le XD05 Plus, sur cette 05BL Pro j'obtiens bien la liaison en LDAC 96 kHz. Est-ce que cela apporte réellement à l'écoute comparé à l'APTX sur le 05BL précédent?
À mon avis pas énormément... un peu quand même.
Ça et l'ajout de l'AOP Burson V5i propulsent le XD05 Plus vers des écoutes vraiment agréables, addictives j'ai du mal à me décoller de cet appareil!
Si vous voulez l'extension Bluetooth sur le XD05, pour le même prix choisissez plutôt la BL Pro, pour le nombre de codecs compatibles. Elle a une prise usb-c pour la charge batterie, une autonomie un peu supérieure j'ai cru comprendre.
