AUDIOPHONICS Absorbing Acoustic Panel 630x630x40mm (Unit)
Reference : 10633
49,90 €tax incl.
41,58 € tax excl.
These panels are the ideal aesthetic solution to easily and quickly correct the acoustics of a room.
Indeed the plasterboard which is widely used in habitation or in the professional premises has a significant reverberant effect notably because of its hard and smooth surface.
In Hifi, the acoustics of a room are too often neglected, the reverberations engendered by the speakers have an effect probably more important than what you can imagine.
Positioning these slabs on the ceiling between the speakers and the point of view can only be beneficial, reducing a lot of the reflections that happen to you with a slight delay, blurring the signal.
These panels provide an efficient and inexpensive solution.
They are easy to implement because they are light and already finished, they are ready to stick to the ceiling.
Their ease of implementation by bonding together with a small footprint makes it possible to meet many architectural constraints in particular in renovation.
For their sound absorption qualities and timeless design, these panels are designed and adapted for all rooms wishing to receive an effective and aesthetic acoustic correction treatment.
They are made of absorbent foam with a density of 11Kg / m3, coated with a veilof paint RAL9016.
This foam is free of natural or synthetic mineral fibers, halogenated or CFC.
They have a bevelled finish on their edges, allowing them to be used without a frame.
Characteristics :
  • Thickness: 40mm
  • Size: 6030x630mm
  • Color: Light gray RAL 9016
  • Temperature resistance: -60 ° C to 150 ° C
  • Fire classificationM1
  • Thermal conductivity: 0.034W / mK
  • Sold per one unit
