DAYTON AUDIO GS2.1 Active Subwoofer with 2.1 Amplifier 30W + 2x15W
The Dayton Audio GS2.1 is a unique and versatile solution for full range reproduction in small spaces. This compact active subwoofer is equipped with a 6.35cm (2.5") driver, a passive radiator of the same diameter and integrated mounting brackets for a convenient and discreet installation. In addition, simply connect a pair of stereo speakers to the binding posts and plug an audio source into the 3.5mm AUX input for full sound reproduction down to 50Hz.
Reference : 16304
115,00 €tax incl.
95,83 € tax excl.
Dayton Audio GS2.1
Dayton Audio GS2.1 Subwoofer actif avec amplificateur 2.1 30W + 2x15W
The integrated amplifier not only powers the on-board speakers but also allows the addition of two stereo speakers with a power of 15W each (30W in total). The GS2.1 also provides a volume control and bass level management. It is also equipped with a grounding cable, which may be necessary depending on the usage scenarios. The whole system is powered by a 15VDC 4A power supply (sold separately).
Product typeSubwoofer
2.1 Amplifier
Channels2.1
Speaker drivers1x Speaker driver Ø6.35cm (2.5")
1x Passive radiator Ø6.35cm (2.5")
High-pass output power2x15W RMS
Subwoofer output power1x30 RMS
Max. SPL97dB
Subwoofer frequency response50Hz - 150Hz
Second order high-pass frequency response150Hz - 20kHz
THD+N< 0.2%
Frequency response20Hz-40kHz
Supply voltage15VDC 4A (power supply sold separately)
Dimensions209.5 x 101.6 x 98.4mm
Finish / ColorBlack vinyl
GrillRemovable
Weight1.58kg
Impedance (Ω)NC
Lowest frequency (Hz)50
Highest frequency (Hz)20000
Power (W)30.0
Power (W)15.0
Speaker typeActive
Performant ...
Petit appareil qu'on peut monter sous étagère étant le complément idéal pour mes enceintes Artsound AS 410 assorties d'un amplificateur de qualité ... discret, performant au point que mon entourage s'étonne de la qualité issue d'enceintes faisant 16 cm de coté ...
This review has been posted for DAYTON AUDIO GS2.1 Active Subwoofer with 2.1 Amplifier 30W + 2x15W
The Dayton Audio GS2.1 is a unique and versatile solution for full range reproduction in small spaces. This compact active subwoofer is equipped...
